Hi ES, I was searching for a Low Voltage Cut-off... regulator/'device'
Still setting up, or gathering bits for a 36v 250w Xiongda Hub build, for the rear of a 27.5+ bike, this time with only PAS and e-brake, no HAL, no throttle, no display.
Battery- Circuit breaker- LVC(?) - Controller
Rather than rely on the BMS LVC in the shark pack, can I simply wire in an additional LVC (as a first line 'empty')?
If so, how so? Anyhow, thanks in advance for any advice?
