Hi All,
Noob getting into battery building. I got me the Malectrics spot welder for Christmas and I'm looking for thoughts on powering it. I'm leaning towards an ultra capacitor so wanted to put it out there and get some recommendations or thoughts on what I'm forgetting about.
The two options I am comparing are a parallel pair of Turnigy Graphene 3S batteries or a packaged ultracapacitor. Both options cost about the same at approx CAD$200.
https://hobbyking.com/en_us/turnigy-graphene-6000mah-3s-75c-lipo-pack-w-xt90.html?wrh_pdp=3
https://www.maxwell.com/images/documents/datasheet_16v_small_cell_module.pdf
I'm leaning towards the Maxwell ultracap as it
- should have a much longer life span then the battery, I won't be spot welding regularly and wouldn't want to pull the kit out and find the batteries output had significantly decreased (aging) or died completely.
- at Maximum Malectrics voltage it's closing in on the max Malectrics amps, 14V/0.0022Ohm (ultracap ESR) = 630A if I'm doing that correctly. I understand the malectrics max amps to be to be about 800A max
I did look at the kWeld kCap as another option for a similar price. Although the ESR is much lower and allows more amps, if I'm understanding it correctly, I'm thinking that I'll only be able to take so much of that (800A max) and the lower voltage will give me less opportunity to tweak the voltage. Am I missing something?
I'm planning to ideally start with 0.2mm nickel strips and then I'm interested in trying some of the copper & nickel "sandwiches" I've seen talked about here.
Thoughts, comments and ideas welcome.
