Uh, if you take a gander at the current prices, they are nothing to get very excited over. Maybe he has not marked them down yet.The Journey Guy said:So, maybe there is still hope for getting product at a good price, at least for a while?
WonderProfessor said:Uh, if you take a gander at the current prices, they are nothing to get very excited over. Maybe he has not marked them down yet.The Journey Guy said:So, maybe there is still hope for getting product at a good price, at least for a while?
That's what people were hoping with Brett too. Good luck.The Journey Guy said:So, maybe there is still hope for getting product at a good price, at least for a while?
TylerDurden said:That's what people were hoping with Brett too. Good luck.The Journey Guy said:So, maybe there is still hope for getting product at a good price, at least for a while?
Canis Lupus said:BionX
rguy56 said:Re: "BionX"
To see a posting with only the name of the manufacturer, and no explaination, has no value at all, and in my opinion simply calls some question toward the poster and their motives. If they have a story, they can tell it. Otherwise, they literally have nothing to say.
Bob
Delicate and tricky system (concealed voltage switcher on charger and no warning anywhere about it); over priced to start with ( nearly twice as expensive as a comparable DIY kit); over priced to maintain ($1000 for a replacement battery - they even gouge you on something like an axle nut); won't honour their warranty or take responsibility for their own shortcomings and lack of information which causes problems - installation information; downtime issues because they insist everything be sent back to them for repair - even replacing a fuse will void their warranty, will use any excuse available to them to avoid warranty; components are not made in Canada, which is the impression BionX likes to give consumers; the battery compartment, locking mechanism, one of its main selling points, is poorly manufactured.
It's a closed system designed specifically to make you totally dependent upon their whims and pricing, resulting in wasted time and money the moment the slightest thing goes wrong, which they exploit by overcharging.
http://endless-sphere.com/forums/viewtopic.php?f=26&t=14383&start=60
To Whom It May Concern,
I refer to RMA number 13003. The repair number relates to a motor, which had a wiring problem and a recharger which had blown up.
I have been advised by the seller located in Utah that you are not honoring the warranty although he has not explained to me your reasons. This is despite the items being sent back to you being near new. The charger is said to cost $78, being a replacement, and $298 for the motor repair.
Firstly, the charger. The problem with the charger could have easily been avoided if your company placed a warning on the recharger unit which was clear for the user to see about the voltage switch on the back or advised the user of the voltage switch on the back of the recharger in the user booklet provided. By not doing either of these things, it is a shortcoming of your company, not the fault of the user, which has caused the problem of the recharger to blow up because of an incorrect voltage setting when first being used as supplied.
You ought to take responsibility for this oversight and replace the recharger for free as well making sure that this problem does not happen with other customers. This can easily be done by arranging a highly visible sticker to be placed on the rechargers acting as a warning. Longer term, you should include the information in the user booklets as a double measure against the problem occurring. Better still, supply a recharger which has no need of a voltage switch and is made to handle different voltage automatically.
Secondly, the price of the repair to the motor at $298 seems excessive. It seems to be the price of a replacement motor at wholesale price. The fixing of the wiring for the motor I sent back could not possibly cost $298 in my opinion. If the motor is being replaced, please send me back the damaged motor, together with the new replacement motor I am purchasing. I am being charged for a new motor, so I want my old motor back also.
If, on the other hand, the $298 is for labour and parts to fix the old motor, please itemize the charge of labour and parts in the invoice for the work, seeing as how this is not a warranty matter in your opinion, but a charge for services and parts rendered and supplied. I will know whether the motor is a replacement because I have the details of the one I sent recorded here.
Lastly, I wish to make known my total dissatisfaction with the amount of time it has taken your company to deal with the repair, particularly in regard to the charger. It ought to have been obvious the charger needed replacing within minutes and a replacement should have been arranged immediately. Instead, you have taken several weeks to react. Meanwhile, I have been left with a flat battery which needs recharging urgently instead of it remaining in a prolong flat state suffering damage.
You are well aware what conditions will cause damage to the type of battery you supply with the kits. Nonetheless, this fact has not motivated your company to do everything in its power to help prevent such damage to the battery you supplied. Instead, you have dallied at my expense, when promptness was the need of the moment.
I look forward to a prompt reply relevant to the points i have raised.
Best regards,
The Mighty Volt said:Canis Lupus said:BionX
What is wrong with BionX- they are heavily touted, surprised to hear that anyone had an issue with them!!
999zip999 said:Bionx it seems like a dream, WAKE-UP the battery is over price to replace,The motor lacks power it peddle assist only. But it is a kit. And costly. And seem's to run for a long time.
conhis_buyer said:yes! avoid conhis motors! they have my money and i have nothing. and all they do is lie, lie lie...
Lessss said:maybe I should put this in it's own topic.
Those guys are usually fine... maybe if you look very closely at the page, you can see the message at the top:slacker said:ecowheelz,on their website today they have greenline electric bikes for 0.00 and 7.95 shipping.called to confirm and they were extremely rude and had quite the attitude. needless to say i will not be recommending them to anyone.beware
