afair steel is 10x of copper and brass is 4x of copper. i don't know if this really matters a lot for these very short distances?!riba2233 said:Standoffs can be brass, but yeah, copper is still much better.
yes of course. i was speaking of the other two boards. my mistake. but as i rethink it: i guess you planned to stack all boards above of each other. so if the FETs are screwed to the box the other boards will be fixed as well. correct?Animalector said:There's six mounting holes through the FETs
stupid me. those are to-247 cases. their heat spreader and form factor is different from the to-220 i'm used to work with.Animalector said:Have a look back on page 3 at the CAD render.. the fets all mount flat facing down, so the bottom surface becomes the heatsink.. so unlike an Infineon that have the FETs bolted to the side of the case, these will be screwed to the base or top....
should work right???
you're sure it's m4? the hole of a TO247 is 3.56mm which is the right diameter for an m3. a thru hole for m4 is between 4.3-4.8mm.Animalector said:... Drill the base of the case.. a 1:1 PDF template is already uploaded on the first post of this thread.. then just insert m4 screw. tighten. Simple. ...
thanks. yes absolutely. soldering the nuts to the pcb will make installing as lot easier, if not even possible at all (when you install it in a case).Animalector said:sure thing. I didn't measure just guestimated... M3 it is..![]()
the important thing is that we use a nut...![]()
Those PDF's should be 1:1..
how would you fix the standoffs to the board? the problem is: you have a case with the FETs touching the inner side of it. so you insert the screw from the outside. it goes through the box, through the FET, through the board. and then you have to put a nut on it. but you can't reach inside. so you need to fix the nuts first on the board before you start installing it. soldering is just to keep them in place. once you screw the FETs down there will be no more pressure on the nut.Alan B said:Using short standoffs would be easier than soldering nuts to PCBs. Solder isn't very mechanically strong, tension, thermal expansion and vibration will likely break the bonding.
izeman said:how would you fix the standoffs to the board? the problem is: you have a case with the FETs touching the inner side of it. so you insert the screw from the outside. it goes through the box, through the FET, through the board. and then you have to put a nut on it. but you can't reach inside. so you need to fix the nuts first on the board before you start installing it. soldering is just to keep them in place. once you screw the FETs down there will be no more pressure on the nut.Alan B said:Using short standoffs would be easier than soldering nuts to PCBs. Solder isn't very mechanically strong, tension, thermal expansion and vibration will likely break the bonding.
if you add stand offs to the pcb the overall height will be even more (+1cm at least). we (i) try to make the controller as small as possible. the three stacked pcbs add up to some height already.Alan B said:Threaded standoffs can have screws in from both sides. No soldering needed.
