knightmb
Yeah, I couldn't resist. It was on sale for only $279.99 + Tax, so I figured why not see how the generic e-bike from Wal-mart stacks up to everyone else's custom e-bikes.
Range (claimed)
18 Miles (29 Kilometers)
Top Speed (claimed)
15 MPH (24 KPH)
Max Power (claimed)
450 watts
Test Conducted 12/2/2006 @ 1:30PM
Environment Stats
Rider Stats
Bike Stats
Summary:
The day for this test run was sunny and clear. It was cold, so that might affect the test somewhat because the batteries lose some power when they get cold. But since it sat in the garage and it's such a short drive to the park, I ruled out the cold being a major factor, especially once I start driving around because that will heat up the batteries anyway. If anything, the cold weather would keep the motor and controller cool, so less resistance for the power to the motor.
I put on my coat and gloves because I knew this was going to be a cold ride. I started on laps around the park from the 1 mile marker (just like last time). The bike uses an instant start controller, so away I go for many laps around the park. During the ride, speeds stay steady between 15 and 17 MPH. The ride was very straight forward and the cold weather made the park a ghost town. Less people to avoid so it was easy to go full throttle the entire way. I had no problem going up and down hills, the bike had plenty of torque to maintain the 15 MPH speed that it's rated for.
The ride ended up being a little shorter than I thought it would be, the bike finally died at the last hill before another lap, so I pedaled it up the top and used what remaining battery power to get me the rest of the way. One thing to add to this summary, the charger gets really hot when charging. But it won't have a meltdown, so don't worry about the charger when it's doing a 6 hour charge on the batteries and gets hot to the touch.
It was a very comfortable ride, here are the results.
Test Ride Results:
Pros:
Cons:
- Weight: 70 lbs
- 26" Wheel Size
- 24 Volt 12AH - SLA Battery Pack
- 450 Watt Rear Brushed Currie Motor
- 7 Speed Rear Derailer
- Twist Throttle
- Kill Switch on Front Break (when you squeeze the front break it has a circuit break that cuts power to the motor even if you are giving throttle)
- 6 Hour Charger (smart charger)
- Front Shocks
- Seat Shocks
- Comfortable Hybrid Road Tires
- Kickstand (strong enough to stand up the bike that is)
- Aluminum frame, unisex
Range (claimed)
Top Speed (claimed)
15 MPH (24 KPH)
Max Power (claimed)
450 watts
Environment Stats
- Weather: Mostly Sunny
- Winds: NNE 7 MPH Gust on Occasion
- Temperature: 48 F
- Humidity: 40%
- Barometer: 30.39
Rider Stats
- Gender: Male
- Weight: 172 lbs
Bike Stats
- Bike Weight: 70 lbs
- Tire Pressure: 53.5 PSI both Front and Rear Tires
- Batteries: (2) 12V @ 12 AH - SLA Battery Packs, Full Charge
- Battery Age: Purchased 11/30/2006 - Unsure of Age
Summary:
Test Ride Results:
- Total Ride Time: 48 Minutes
- Max Speed: 19.2 MPH (30.9 KPH)
- Level Top Speed: 17 MPH (27.4 KPH)
- Average Speed: 14.2 MPH (22.9 KPH)
- Total Ride Distance (unassisted): 11.5 Miles (18.5 Kilometers)
Pros:
- Cheap
- Good first "e-bike"
- Everything included (batteries, charger, motor, controller, bike, already built)
- Safety feature on brakes to prevent braking and motor at the same time
- Sturdy design
- Easy speeds to maintain
- Gears top out at motor max speed
Cons:
- Chain comes off front sprocket when shifting into really low gears (1st, 2nd, or 3rd). You basically have to get a chain guard for the front sprocket to prevent this.
- Charger gets really hot, almost scary to anyone that's never used one before.
- Low Speed - Debatable of course
- Low Range
- SLA Batteries, you have to be careful to charge the batteries as soon as you are done riding or you'll kill them if left in the uncharged state for too long
