landlord said:Hello everyone! I'm a new member on this forum and just ordered my first AM1000. Loads of information on this thread! Fully read through every page and I now have a solid idea of what to expect.
But one of the most important questions that I haven't been able to answer...
What color frame should I get?! Opinions? :lol:
jeffdkeyes said:Grey...love the grey. I ordered mine in May - figuring out what color my wife would want was harder than anticipated.
What "extras" are you going to order?
Jeff
tsellers said:Interesting. Why the change to 29" wheels?
tsellers said:Thanks, that's an interesting point. I have a Canondale 29'er MTB, a Giant Full-e (27.5), and a Frey M600 (27.5). The latter suffers from horrendous pedal strike problems. I didn't consider that perhaps clearance would improve by a move to 29" rims, as I assumed the frame geometry on the M600 would not allow for it. Ironically I just bought a second set of 27.5 rims for the Frey for studded winter tires.
I just had a horrible pedal strike with 152mm miranda crancks , pedal and crack bend.landlord said:tsellers said:Thanks, that's an interesting point. I have a Canondale 29'er MTB, a Giant Full-e (27.5), and a Frey M600 (27.5). The latter suffers from horrendous pedal strike problems. I didn't consider that perhaps clearance would improve by a move to 29" rims, as I assumed the frame geometry on the M600 would not allow for it. Ironically I just bought a second set of 27.5 rims for the Frey for studded winter tires.
I've been reading about the pedal strike issues on the AM1000 (sounds similar for the M600 then). Seems like a recommended upgrade is switching to shorter cranks (150mm) which I will most likely change once received. I wasn't sure if it could be an option for them to switch to 29" wheel for this frame however when I asked, they had an option available.
jeron said:I just had a horrible pedal strike with 152mm miranda crancks , pedal and crack bend.landlord said:tsellers said:Thanks, that's an interesting point. I have a Canondale 29'er MTB, a Giant Full-e (27.5), and a Frey M600 (27.5). The latter suffers from horrendous pedal strike problems. I didn't consider that perhaps clearance would improve by a move to 29" rims, as I assumed the frame geometry on the M600 would not allow for it. Ironically I just bought a second set of 27.5 rims for the Frey for studded winter tires.
landlord said:I wish my order was shipping that soon! I just started the whole process. I'm probably 3 months out until I even see it. How long was their production process for your order?
tsellers said:We sent the initial deposit to Frey for 4 builds on March 19. They are due to arrive in Vancouver via sea on July 28. Approx 19 weeks.
tsellers said:...I've had cars arrive from Japan in as little as 11 days.
Durtdemon said:...I ordered the bike in black so the battery doesn't stick out so much from the frame. (Maybe get into some trails that might not look kindly on electric.)
Didn't want hardwired lights drawing from the battery.
tsellers said:Didn't want hardwired lights drawing from the battery.
On the Frey M600 with the stock Shimano LED headlight/tail light combo, and the controller display backlight on, the current draw from a 52V battery is .11 amps when all 3 Led's and tail light are turned on. For that particular battery (which is 10Ah), that draws 1.1% of my total capacity. With the headlight switched off, the tail light draws .01 amps, or .01% of the capacity of that particular battery.
No need to waste bike power.
