tsellers said:Tonight I was pondering the frame on my M600 and it 'seemed' like there may be room for a... 29" rim
Does anybody know if the Frey EX will fit 29" wheels? And if so, with the standard 2,8" tires, or only with limited tire width?
27.5 plus is about the same diameter as thinner 29". Might be able to fit, but I would say definitely limited on width.18650 said:tsellers said:Tonight I was pondering the frame on my M600 and it 'seemed' like there may be room for a... 29" rim
FlyingFinn said:Less than a year old bike:
Clutch broke. The old clutch pawls had completely destroyed the main gear teething. Had to buy a new clutch and main gear.
Now when re-assembled getting error 30. Doesn’t work at all even though all wires and main board were ok. Most likely another fried motherboard. Wonderful!
First time I’m really regretting my Bafang Ultra...
Hi, I had an earlier version without a heat sensor and burned a winding. I can tell you, you'll notice that it's burned. This was after heavy abuse of pushing up a friend on a 20% incline in mode 5 for 20 min. Yes, the smell is there, even after you store the bike in your garage and smell the next ...
barbarossa said:FlyingFinn said:Less than a year old bike:
that's a pity. how many km did your clutch ?
I saw this error before.
unfortunately during reassembling a friend of mine squeezed 3 of the white controller cables. not good. controller failure = 30. wires could be soldered again and failure was gone - everything ok.
that does not mean that you have squeezed cables during reassembling but I would highly recommend to examine each of the controller wires carefully - inside motor (and outside - but normally error 30 means inside motor). the most critical time of reassembly is to put the controller cover side back to the motor. I always take a strong flashlight during the last millimeters (when fitting sleeves match) and try to watch if I would squeeze some wire(s) or not.
hopefully problem are only squeezed wires...
FlyingFinn said:barbarossa said:FlyingFinn said:Less than a year old bike:
Thx for your view. Trying to resolve.
Bike had 3200 km’s when the clutch broke.
barbarossa said:FlyingFinn said:barbarossa said:FlyingFinn said:Less than a year old bike:
I have a little more km but still working - of course with higher voltage and higher rpms to avoid clutch damage, the clutch can't melt like the nylon gear of BBSHD and might be the weakest part compared to the steel gears. You have a 48v battery and may I ask how many teeth your front chain ring has ? I guess 44t !?
another reason might also be the second critical time of assembly: putting the motor back in the frame. sometimes the battery wires or other wires may overlay the main harness cable (to display/throttle/brake switches -> big white plug). there is not much room between motor and frame so the wires are squeezed in that case. but i don't know exactly if this might also result in error 30 !? but it could be if just TX/RX signal is lost (TX or RX wire is damaged)...
cheers
HT 1000 is done. AM 1000 is in production still (given my numerous changes, I'm OK with that) - but i did get a pic of the frame. Freaking love the color.landlord said:jeffdkeyes said:Grey...love the grey. I ordered mine in May - figuring out what color my wife would want was harder than anticipated.
What "extras" are you going to order?
Jeff
Yeah I saw a photo of the grey somewhere, looked pretty nice!
So far nothing too extreme with the extras or upgrades.
XL frame, upgraded to 29" wheels w/ Maxxis tires
Sram EX1 Groupset - seems expensive but the extra strength would be nice.
Gear sensor/lights
I'm sure I'll be upgrading much more once I receive it.
Did you ever look at Chines scooters? I'm talking about these 50cc that you can buy for about $1000. After about a year of use they are done, dead, kaput.FlyingFinn said:barbarossa said:FlyingFinn said:barbarossa said:that's a pity. how many km did your clutch ?
cheers
This is the end result. Main gear is busted. Clutch is busted. Less than a year old bike sits useless. Contacted Frey. Let’s see their response. Wonderful.
FlyingFinn said:This is the end result. Main gear is busted. Clutch is busted. Less than a year old bike sits useless. Contacted Frey. Let’s see their response. Wonderful.
Daxxie said:FlyingFinn said:This is the end result. Main gear is busted. Clutch is busted. Less than a year old bike sits useless. Contacted Frey. Let’s see their response. Wonderful.
How did you do that?
Do you have superpowers?
I really abuse my Ultra bike (2500W) and my clutch is like new.
Maybe I don't pedal hard enough?
Maybe to much grease?
Ecyclist said:Did you ever look at Chines scooters? I'm talking about these 50cc that you can buy for about $1000. After about a year of use they are done, dead, kaput.FlyingFinn said:barbarossa said:FlyingFinn said:Thx for your view. Trying to resolve.
cheers
lemonsqualsh said:Does anyone know if there is any other way of sourcing the additional batteries other than going to Frey?
lemonsqualsh said:Purely the shipping cost $150. Seems excessive.
My 2.5 year old 17.5 ah battery is hanging in there, but a couple of months back I priced out a replacement with the following company and it was 40% cheaper than going through FLX. Many ebikers on the FB group "Ride FLX" have had positive battery buying experiences using Susie Cen who is a sales rep for aijiu power, a large battery builder servicing specific Chinese frame designs (Frey, FLX, more). She recently posted a thank you and promo letter to the aforementioned FB group. I'll repost it here.lemonsqualsh said:Does anyone know if there is any other way of sourcing the additional batteries other than going to Frey?
Yes, it is very expensive especially considering it is a Chinese junk. That was exactly my point.FlyingFinn said:Ecyclist said:Did you ever look at Chines scooters? I'm talking about these 50cc that you can buy for about $1000. After about a year of use they are done, dead, kaput.FlyingFinn said:barbarossa said:I have a little more km but still working - of course with higher voltage and higher rpms to avoid clutch damage, the clutch can't melt like the nylon gear of BBSHD and might be the weakest part compared to the steel gears. You have a 48v battery and may I ask how many teeth your front chain ring has ? I guess 44t !?
cheers
FYI This bike cost three times as much and is less than a year old.
Ecyclist said:Yes, it is very expensive especially considering it is a Chinese junk. That was exactly my point.
You can buy like new Haibike for that money.
https://losangeles.craigslist.org/sgv/bik/d/diamond-bar-haibike-xduro-full-seven/7169167792.html
I just build my own e-bike.
Ecyclist said:Yes, it is very expensive especially considering it is a Chinese junk. That was exactly my point.FlyingFinn said:Ecyclist said:Did you ever look at Chines scooters? I'm talking about these 50cc that you can buy for about $1000. After about a year of use they are done, dead, kaput.FlyingFinn said:This is the end result. Main gear is busted. Clutch is busted. Less than a year old bike sits useless. Contacted Frey. Let’s see their response. Wonderful.
