cloudcover
- Joined
- Sep 8, 2009
- Messages
- 30
hi folks -
i'm about to embark on a bike conversion project and have been browsing through numerous posts on this forum, which have been very helpful. but before i get too far into it, i was hoping to get some guidance to steer me in the right direction for further research. here's my situation:
• starting point: jamis coda comp flat-handle road bike -- steel frame with a carbon fiber fork -- about 25 pounds (details here: http://www.jamisbikes.com/usa/thebikes/street/coda/09_codacomp_spec.html) with a 160 lb rider.
• primary objective: make it easier to deal with the numerous hills where i live, some of which are very steep
• secondary objective: keep the overall weight as low as possible, so i can still contribute as much energy as i want by pedaling
• tertiary objective: have things look as elegant/stealthy as possible (ideal would be something like the cytronex bikes: http://www.cytronex.com)
• NON-objective: i don't care about going fast -- 20mph maximum is more than enough for me -- i'm not in a hurry.
• NON-objective: i don't have a particular budget and so don't need to find the least expensive solution -- but at the same time i don't want to pay more than is necessary. in short, i'm interested in getting value for the money.
• NON-objective: i'm not planning to use the electric power as the sole source of power most of the time -- i don't mind pedaling (i have a motorcycle for when i really don't want to pedal)
and here are my questions:
1. motor: given that i have a carbon fork (and some other positive factors), i was thinking that i'd probably use a rear hub system. but there seem to be numerous systems out there and i'm having a hard time telling what would be the best option, given my objectives. the main systems i've seen based on the research here are ezee, nine continent, bmc v2-t, and crystalyte (not really into bionx, given that it's a proprietary system). it looks like the ezee or bmc ones might be best suited for hills, but that's just my impression. any suggestions?
2. battery: my typical route for running errands is about 12-15 hilly miles roundtrip. my guess is that a 36V 10aH LiFePO4 battery would suffice. but does a 48V battery (instead of the 36V) give me better torque for hill climbing? also, i'd like to have extra capacity -- in case i needed to go on a longer trip now and then. in any event i wouldn't want more than the total weight/range of something like a 48V 15aH battery.
ideally, it would be nice to have something that can be configured for lighter vs longer range. for example, the giant twist freedom dx bike has two battery packs, and you can use just one if you know you won't need the longer range, or use both if you will. i've read about some of the custom setups using bosch/makita/etc batteries, but that seems pretty complicated. if i can use only one battery, then i think maybe 48V 10aH might be a good compromise between range and weight.
so i'd love any suggestions on the battery issue. i've been looking at the pingbattery.com site, which seems to have several options and really good prices. but i'm not opposed to a battery module that's designed specifically for use in bikes.
3. battery mounting: from what i've read, it sounds like with a rear hub motor, it would be nice to have the battery mounted somewhat forward on the bike (in terms of weight distribution)...like on the downtube. but i haven't seen any good options/suggestions for how to do this, as a practical matter. i'd love links to any suggestions for that.
and if there's no good option for mounting mid-bike, the idea of using paniers seems the most elegant/stealth option. are there any descriptions of how best to do that, including specific parts/sources/etc? especially if i'm using something like a pingbattery.com unit.
one thing i want to make sure about is that the battery is securely mounted, so it doesn't rattle around when i ride across bumps, etc.
4. anything else?: is there anything else significant that i should be thinking about that i haven't mentioned above?
thanks in advance for any guidance!
