amigafan2003 said:Greenbike kit now have the 48v750w system.
http://www.greenbikekit.com/index.php/bafang-8fun-mid-crank-driving-bbs-02-kit-48v-750w-central-driven-motor-kit.html
How easy is it to overide the 25km/h speed limit?
mwkeefer said:amigafan2003 said:Greenbike kit now have the 48v750w system.
It's simple, get the kit and by the time you have it... Ill have posted a FULL technical breakdown with mods and all
I'm even working at reverse engineering the CPU and EEPROM to decode the communications protocol and offer a open source software package for changing the settings...
Be patient
Mike
Be patient
Mike
spinningmagnets said:The French pedelec forum http://www.cyclurba.fr has a member selling a 4-arm 104-BCD spider, CNC aluminum, with chainrings available from 32T-48T. This is probably appropriate for France since they have significant mountains (Tour de France, etc), but for US customers, perhaps a 5-arm 130-BCD spider might be more appropriate. A quick Google shows chainrings are readily available from 38T-60T.
I don't know if the bikemotive spiders will fit, could someone post the interface of the BBS01-2? :
mwkeefer said:It's simple, get the kit and by the time you have it... Ill have posted a FULL technical breakdown with mods and all
Be patient
Mike
greenspark said:The biggest challenge in installation is the sloppy way some bike manufacturers finish the inside of their bottom brackets with tube protruding into the 33.5 mm shaft area. We've had to grind two bikes already to get the BB back to 33.5mm all the way through.
Kai said:greenspark said:The biggest challenge in installation is the sloppy way some bike manufacturers finish the inside of their bottom brackets with tube protruding into the 33.5 mm shaft area. We've had to grind two bikes already to get the BB back to 33.5mm all the way through.
My bottom bracket is too narrow inside and doesn't accept the bafang drive. Could you show me what kind of reamer tool you used to ream the bottom bracket to 33,5 mm?
Did you just re-thread the existing threads longer all the way through? If you used a reamer, I hope your process didn't destroy original bottom bracket threads.
Warren said:"
math 48-13 @ 90 rpm, on 26 x 2.125 = 25.6 mph
spinningmagnets said:Have to ever ridden a 48V X 25A = 1,200W direct drive hub? If yes, how does this drive at 48V stack up as far as performance "feel"?
