My 36 volt/18 amp/46 tooth, BBS-01 arrived from BTN (advertised as 250 watt version), and is installed. Nice unit, I suspect my battery is now the weak link in the system. Will do it's first commute on Monday.
Notes.
Won't work without the display connected.
Max speed could be set as high as 40km/h.
C963 display has power (watt) readout.
Questions.
When entering settings mode on C963 what are the first two options? (I kept pressing mode until i was setting speed limit). Will try and take a photo.
Can the aux control panel be removed from the C963 display?
Notes.
Questions.
