Chalo
100 TW
I put these motors in the hands of technically ignorant and personally irresponsible pedicabbers riding sometimes rented trikes. So I run them at 36V and 22A. None of them have been cooked yet!
ebike11 said:Hi guys..im also running a 3000w motor with my Cycle Analyst V3.
I am using the magnet on the spoke and pickup sensor/cable from the CA3 for the speedometer.
What is the # of poles are you guys setting your CA to? Stock firmware has it set at 23 poles but the speedometer doesnt work...stuck at 0.
Thanks
Then you just need to disconnect the non-shunt/power wires temporarily. Anything that powers the CA or allows it to read current is necessary. (if you can't see the power usage you can't tell if things are working right)progrock said:BTW, the Cycle Analyst does not have it's own shunt... I wired in the CA connector myself, and wired across the controller's shunt.
In the testing you need to apply continuous throttle, but at it's lowest range, so you can see the stable current as the motor spins.progrock said:I am only tapping the throttle repeatedly
<snip>
I also saw the Amps running in the 2-3A range from my light taps to the throttle (not too bad from what I'm expecting).
If you do this then you don't know what is causing any particular behavior--if it is the CA or the wiring or a defect.EDIT: BTW, I ended up keeping the Cycle Analyst in use for now, running the throttle through it... that way I could limit the Amps as well as view the current usage.
If the CA isn't already calibrated for the shunt value, then any current readings you got during testing previously may be very different from reality. However, as long as the current is still low, and you found a working combination that is the lowest current of all of them, then that should still be ok.progrock said:I will be attempting to calibrate the CA correctly.
Bullfrog said:Just found this topic...to be honest, I am too lazy to go back and read all 113 pages, can somebody summarize regarding two questions?
1. How does the Cyclone compare to the LIghtning Rod Small Block (LRSB) as far as performance and reliability?
I can see the price differences and obviously the LRSB is more money. I am currently running a BBSHD and just want more power...tried to buy a Ludicrous controller from Luna but they won't sell me one because I haven't spent enough money with them. I understand it is a business decision and nothing personal. So now I need to make an engineering decision and decide which option to go with...Cyclone, LRSB, or stick with my BBSHD and run an external controller.
2. If I run a 3 speed Sturmey Archer rear hub (CS-RK3), how does it hold up with the Cyclone or the LRSB?
Question is assuming I take care of the hub, don't shift under power, keep it lubed, etc. The reason I want to run the CS-RK3 is I can run a single cog and get my chain line perfect. It is set up for a cassette but I plan to use a single speed conversion and one cog. Long story on the chain line but this will allow me to get it straight.
My sincere thanks for a summary.
Bullfrog said:Thanks robocam...great info.
I ride off road 100% of the time. Mainly single track with a maximum speed of approximately 15-17 mph.
Has anybody run a Sturmey Archer CS-RK3 rear hub...or any 3 speed hub for that matter with the Cyclone? How did it work...or did it work? My plan is to gear it so that I run 2nd gear (straight thru) most of the time and have 3rd gear just to get to and from the trails.
