Hello everyone, this is my first post. I have installed 2 cyclone 3kw on two of the same bikes found 2 almost identical builds, one for my gf and one for me. Without all of the info on this forum I would have never gotten it done as well as I did. Everything came out mounted straight after some trial and error on the first bike which is mine and the second bike, my gf's everything was close to perfect from start since I learned my lessons from the first build. I am running a 52v 20ah triangle pack from UPP batteries 14s8p, with the stock 40a controller.
I have been pushing the motor to the max on some rides but only to the max of what 52v 40a, and I have put roughly 60 miles on my build. The only thing I modified on my build was I drilled the threads out on the the bolt holes where the motor mounts attach so that I could replace the 4 bolts with 2 long bolts and a nut and lock washer. I only did this because the small short bolts on the non drive side had stripped the internal threads of their bolt holes and so could not be tightened.
Additionally on my bike I am using a 41t chainring from the 14t motor freewheel and then a 38t chainring to the cassette with a standard Shimano 8 speed cassette. I changed the chainrings because the cassette chainring that comes stock would rub the chainstay and 38t was able to be delivered in 24h. I could probably get a slightly bigger one but not by much. The 41t outer is due to chain length issues and it was the biggest chainring I could find with an odd tooth count and now I am running it without a chain tensioner. I haven't had any chain drops since the change and there is just enough slack that I can deflect the chain in all directions by maybe 1-2mm. I had he tensioner on with this current setup but the tensioner is actually out of alignment enough with the motor sprocket and chainring that with the tensioner under high torque found wheelies the chain would be thrown. On my gf bike in order to remedy the chain/ chainring situation her bike is running the 13t from sbp from the motor to 40t outer chainring, to 36t inner chainring to cassette.
Anyway to the reason I am posting: my bike has recently started to make a squeak noise coming from inside the motor housing. You obviously can't hear it at high rpm because the motor whine covers it up, but when you roll the bike backwards the squeak is pronounced. Also audible if I lift the back wheel and give the throttle at very low rpm. It is definitely not coming from either freewheel. I have taken off the chains and inspected the freewheels and heard nothing, and when I put my ear next to the motor housing it is loudest. Also with the chains off under pedal power there is no squeak so it is not the BB either. I would just like some input on what I should do to start trouble shooting and whether anyone else has had this and if it sounds like a major problem or not. I wouldnt think so but searching the forums here I haven't found anything like this, only one person saying they had squeaking with a BBS02 and they had to grease it. I thought maybe it's the gearbox but it sounds louder to be on the non drive side that the side with the gearbox, but that could also be because I can't get my ear as close to the drive side to listen.
TLDR: Cyclone 3kw is making a squeaking/chirping noise from inside motor housing; would like help and pointers for troubleshooting as well as thouhts and prognosis on how bad of a sign this is.
Thank you for all of your guys help already in the form of the amount of information on this site. Sorry for the page of info, I just wanted to include as much info that seemed pertinent to get to the solution. And if I have broken any rules or made this post in the wrong place I am sorry and I will fix it if need be.
