Tommm said:forcefed said:Hmm can I use regular nuts and bolts instead? I have to attach two chainring to this adapter and get the spacing perfect with the cyclone, not sure those chainring bolts will be long enough, there's currently 9mm spacing between my chainrings.Tommm said:forcefed said:Here's the stock chain ring with the free wheel in the middle, but I think I found the solution straight from sbp http://sickbikeparts.com/freewheel-spider-4-arm-104-mm/
Is 104mm the most common size chain ring? They have 110 and 130mm adapters also.
That looks good. 104 is the most versatile one as it goes from 30t to 52t. Be sure to get chainring bolts and use loctite on them. They are very prone to unwinding and getting lost on the road.
You can get a set of extra long chainring bolts or yea use regular bolts but it might stick out somewhere you don't want it to.
https://www.ebay.com/itm/Sram-Truvativ-Chainring-Bolts-Set-MTB-1-fach-with-Bashring-Steel-Long/392238156554?hash=item5b53374b0a:g:GogAAOSw1fJevY42
Ah ok, found some 15mm ones
