A-DamW
Have you tried isolating components? like maybe remove the planetary gearbox and throttle the motor while grabbing the output shaft with a glove on, inspect the nylon gears for wear/missing teeth, throttle the motor with planetary installed but no drive chain to crankset, etc. ?I'm at a crossroads with this motor. It had been working great for nearly 12 000 km over 3.5 years. It has developed a clunking sound while under load which I initially though might be the bearings or my freewheel crank etc... I have replaced nearly everything in a effort to fix the clunking sound:
all bearings in motor (including bearings on nylon gears etc...)
new crank freewheel
new motor freewheel
new chainrings
new cassette
the test I do is apply a small amount of rear brake to apply a load and then give it a small amount of throttle and the clucking sound is replicated. The clunking sound seems to be related to the rotation of the motor. Any ideas?
Fyi, I have a bunch of cyclone parts if you find the clunk problem needs a hard to find part.
