I am running Shimano HG-62 10spd cassette, its an 11-36T. I am running a KMC 10 speed chain 10.99 IIRC.
I haven't broken a single chain since mile 0 on this kit (and the chain I am running also had about 300 miles on the old GNG) and I am running full-throttle all the time @ 30+ mph, I am also operating my kit on mode # 3 with full unlocked RPM so my crank cadence is 160-180 RPM, and that allows me to achieve my cruising 30mph speeds in 5th gear, so the chain is barely stressed out by spinning the crank so high. I have 1.5k miles and the chain wear hasn't even ticked at .5 wear yet. I suspect is going to last a lifetime.
I haven't had any skipping either, only did once due to a sticking Derailleur cage that was reassembled wrong (my fault) I am also running a Shimano RD-615 Deore Shadow Plus Derailleur (10speed) with the clutch always engaged. My shifting is silk smooth and the bike has been running like clockwork.
I would suggest you run mode #3, crank the RPM to the max and forget about pedaling; seriously, at 30mph your input is insignificant. I do pedal, but just to move my legs, but no work is coming from them except the movement. I don't get why people put up such a stink for wanting to pedal at 30mph on their bike... it doesn't achieve anything except having to run the smallest cog and putting INSANE amounts of force through the chain and thus causing skipping.
So, if you want a bulletproof drivetrain then this the entire setup of what I run. People are welcome to copy it, improve upon the idea, and call it their own idea etc..., my only request would be to please refrain from arguing, question or play down any my design decisions. If you think you know better then by all means, go ahead and do it your way, but don't question my idea or play it down when the fact is that my setup has been running rock solid for 1.5k miles at 30+ mph and 1600 watts average... not a single issue (even after two crashes) and I have every single commute since I installed this kit on video to prove it.
NOTES:
-Do not shift under power, ever. If you do, things will break.
-Do not crosschain, (i.e. run small cog with small chainring, or big ring with big sprocket)
-Limit your wheelies, or better yet, don't wheelie.
Batteries:
x2 6S (22.2V) MultiStar 12000 mAh Lithium Polymer batteries.
Throttle:
Stock ORO throttle hardwired to the controller (no connector)
Controller:
Stock OEM Cyclone, running mode #3 in the speed selector switch. See my video on youtube as to how to enable mode #3.
Motor:
Stock OEM Cyclone 3000W motor with a 13T freewheel sprocket. Support mod with washers to lower the flex induced under load.
Motor-Crank chain:
BMX KMC 410 chain; one half link to shorten the chain. This is a chain I would not run a MTB.
Tensioner.
Direct bolt to plate (no stupid zipties), with a full metal bushing shimano derailleur cog (its a 13T)
Crank:
Cyclone crank with custom built chainring configuration 44T-48T-32T.
Cassette:
Shimano HG-62, 11-36T cassette.
Derailleur:
Shimano RD-615+ Shadow Plus (with clutch)
Crank-Cassette chain:
KMC 10.99 full nickel plated chain, with mushroom rivets and ligthened plates.
Wheel:
WTB double wall deore hub 32 spoke wheel.
This setup will allow you to run top speed in 5th gear, thus you will not snap another chain ever again.
le15otl said:
That is a good point actually haha, you have to be able to cope with and expect wheelies with this kit. Sometimes not wheelieing is really hard up a hill
G, what gear cassette and chain are you running?
I'm using a 9 speed cassette and 9spd SRAM chain and experience some problems on the higher gears.
It sometimes slips, not gripping the cog well enough. And I've snapped the chain about 10 times...
Looking for a good reliable drivetrain setup now.
This is not the fault of the cyclone kit.
