sather said:My son bent it on the third or fourth ride. He likes to do wheelies and ride up stairs. I beefed of the mount and installed an ISIS bb. No problems since except the SBP heavy duty motor freewheel,which they took care of in 1 day. Great service!
Apex said:Yes, I see that the stock controller has the 3way wire set for limiting amps. Do we know for sure what those limits are? I read somwe here it was 20a (low), but not sure of the middle, "factory" setting.
And according to my calculations the 13s10p should get me a 39amp discharge rate. So instead of building a battery pack not capable of full throttle, I would rather keep sourcing 18650s untill I have enough for a proper discharge capability.
And yes, I'm aware of the mount flex issues, as well as the freewheel and crank weaknesses of the stock equipment when pushing max power.
Those will be addressed in the future, but I want to get the battery right the first time. If I'm going to spot weld up a pack, I don't want to tear it down to add cells later.
Apex said:Not sure which welder to pick up.
The sunkko 788 seems draw crazy amps at startup, blowing breakers. The 709a is about what I'm looking for, but I've seen many posts about how unreliable they are.
Of course, the JP kit is no longer available, so it seems there are no good answers for a hobby use spot welder.
DingusMcGee said:get a set of earplugs for yourself -- cheap-er than an ipod.
evolutiongts said:For those of you who are interested.
I wired up my BBSHD to the cyclone 3000w 40a controller. It runs ridiculously well at 74V power is now very similar to the cyclone 3000w I've had both motors.
sather said:The Cyclone 3000 is called "waterproof", but I've had the Cyclone apart and there are no gaskets. The side plates are metal to metal contact with loose enough tolerances that you can work them off by hand. There is no way that the Cyclone motor is "waterproof".
I was shocked to look at the photo of the rusted armature on Karl's BBSHD and the BBSHD has gaskets.
https://electricbike-blog.com/2016/09/16/spray-varnishing-your-bbshd-to-protect-it-from-rust-while-winter-riding/
DingusMcGee said:...It just so happens that during all but the quite moderate trail riding you get a chance to jump a log laying across the trail or bound over a boulder field. Not all my attempts to ride over, across or through these obstacles have gone without some additional contact areas other than the tires. Yes, my motor fins are bent flat and there are scars where rocks have hit the motor bottom....
robocam said:Is the BBSHD as "torquey" as the Cyclone at equivalent currents and voltages? When you say "similar," is it still weaker than the Cyclone 3000?
evolutiongts said:robocam said:Is the BBSHD as "torquey" as the Cyclone at equivalent currents and voltages? When you say "similar," is it still weaker than the Cyclone 3000?
I've had both motors but off the seat of my pants I can't say for certain that the BBSHD is weaker. I'm still having a hard time keep the front wheel down on steep hills. The stock BBSHD never did that.
