DingusMcGee
Robo,
thanks for mention of the new product.
I got this version [your suggestion]:
799USD 36~72V 4kw Coaxial mid drive motor kit: Elite Cr-mo Frame, 4KW Coaxial Mid motor,60A Bluetooth [ programable ]controller and throttle, frame come with head set for 28.6mm tube (up 28.6mm down 30mm)
It comes with head tube 28.6 to 30 which is tapered. I plan on either 26 x 3 or 27.5 x3 rims/tires as I do not like the response you get with big fat tires. I run 26 x 2.7 on my current edirtbikes. I will try a 26" wheel set from one of my current bikes and at the same time fit the bike with one of my enduro seats for getting the ideal seat to ground height I like [likely 29 will be too high but maybe could do on the front] [ all these big pieces are the makings for a longer wheelbase]. Probably I will try to make it a 2 or 3 speed setup for off road performance mostly. Likely the fork will be 200mm Fox.
I have given up on redesigning the motor plates that tikivic and I were discussing that would be adjustable as the current sleeve chain tensioner [posted above] is incrementally adjustable for the capped half link chain and it works quite well.
