gman1971
- Joined
- Oct 17, 2015
- Messages
- 997
adam333 said:The bike looks really clean Gman!
I really like what you did with your fairing. And your fender holder seems of much better quality than those I bought initially with the bike.
Thanks Adam;
yeah, those fenders where the so-called "premium" fenders for 20" front and 26" rears, and they weren't cheap... so I am glad these turned out to be decent, especially after you warned me about KMX fenders poor quality... I was pleasantly surprised.
I also think those will bolt right onto your suspension, so I can't wait... I know, I keep saying that... but ATM I am still wrenching things on the trike and I have a lot of things to finish before its officially done. I deflated the front tires to 50 psi and seems to improve the ride, but I think once I have the suspension I'll be able to keep the pressure higher than that. The rear so far hasn't given me much of of a hassle... so its good.
Today I finally installed all the missing hardware from the motor and reinforced the motor mount even further with a similar solution to what robocam did, except that I only did one side (since one sides is already bolted directly to the frame anyways)
The chainguide solution has worked great so far; so now I can shift the two chanrings as well so its all good. I almost hooked up the horn and the high beams today, but with all other things I have to do (non trike related) I ended up not doing it.
G.
