Apex
So I have been doing some test fittings of the 3000w cyclone motor on an old cro-moly Giant Yukon. This frame has a generous area inside the triangle and the angle of the corner at the bottom bracket is obtuse enough to allow me to mount the motor inside the frame. I really like the idea of this, no motor to catch on logs or curbs, and the position should allow me easily avoid mount flex by laser cutting a delrin "saddle", inside the triangle.
My question is, what are the downsides of such a mount position?
The only drawback I can see as possible is increased stress on the bottom bracket bearings and the chainring freewheel bearing, if at all.
My rational for this concern is that when the motor is mounted in front of the BB, the tension caused by the two chains at the chaining may cancel each other out in a small way. If I mount the motor above the BB then the tensional stresses will no longer be 180 degrees apart, but rather only 90 degrees apart.
Is this a major concern? I can upgrade the freewheel with the Sick Bike Parts heavy duty crank freewheel and an ISIS bottom bracket to avoid premature destruction. I would gladly do this to keep all the mechanicals inside the triangle.
Please post up your thoughts on this, or any other concerns I should be aware of, if any.
