ebike11 said:Hi
when installing the cyclone 3000 on a bike with wider bottom bracket, can you just straighten the bent (thin non-chain drive side) mounting bracket to make it fit on the wider BB? Originally it comes bent for 68mm BB
robocam said:I would think that if you straighten it, it would be too long.
ebike11 said:Hi
ebike11 said:robocam said:I would think that if you straighten it, it would be too long.
ebike11 said:Hi
Hmmm it might be...i guess ill try when the weather warms up. I wonder if anyone else has put the 3000w on a wide BB
Grantmac said:Best thing to do with that thin bracket is toss it in the garbage.
Skaiwerd said:Would be nice to put the cyclone or similar motor inside the lower part of the battery case/box. The prices of the stealth bomber eBay knock off etc. frame have come down considerably. Still no taper headset and only small wheels are useable and it’s heavy.
HrKlev said:So I just ordered a 1800-3000w kit for a fatbike build, it will probably run it with a nucular 6f controller. I have tried searching, and sorry if it has been asked before, but I can not find info about what kind of voltage I should chose if I still want to use the pedals. Cyclone site states rated rpm 800rpm, and I think it is a 14-48 reductipn to the pedals. That is 233rpm to the pedals, which doesnt make sense. After reading a couple reviews, I was under the impression that it is possible to use the pedals together with this kit? I would be really thankful for some real world experience, and what kind of voltage you were using. Thanks!
Something like that yes.HrKlev said:Ok, so to be able to pedal, motor rpm must be ~40-45% max.
dirkdiggler said:Here's what I did to mount the cyclone to eeb frame. No pedals though. Didn't want them. Unfortunately the surron is a better bike for what I want.
Just cut down the stock mount to get it flush with the frame. Had to drill two new holes.
Stanislavchik said:Bought 4.8kw coaxial drive, which chain will fit 2 eat so much power?
Stanislavchik said:No, I have IGH SA 5 speed, so I need 1 speed chain, bmx maybe, i don't know, it is my first mid, i ride on direct drive now...
I saw KMS ebike chains on it's site and yes, they are so expensive, maybe there are more variants...![]()
pwd said:Long story short, my 32T chainring has taken some damage. The one I have looks like this:
Does anyone know where I can purchase a new 32T BCD 104 chainring like this (looks less likely to bend than my old one):
The only place I see them at http://www.cyclone-tw.com/Parts.html and https://elite-motor.com/32t-chainring-with-5-freewheel-holes-bcd-104mm.html but the shipping cost is $30USD/$33USD + $12 for the freewheel; which seems quite high.
