DrkAngel
1 GW
latecurtis said:I will try flux on the other pack. I am curious to see the difference. Also I already made it perfectly clear that I SUCK at soldering. ...
Ouch!
You make it sound like you intend on always sucking at soldering?
LC wrote:
The question is what do I plan on doing with it? I am not really sure however I do know that whatever motor I do decide to hook it up to will be capable of 50mph minimum.:lol: Thanks.
LC. out.
Add ~125lb of cement blocks, to simulate additional weight of necessary motor and batteries.
(Approximately 400lb total weight on a bike designed for a max 100lb 8-12 year old @ 10-15mph)
26"er
(Approximately 425lb total weight on a bike designed for a 220lb(?) adult @ 15-20mph)
still cannot fathom why you guys keep beating a dead horse. sometimes better to wash hands and walk away. I work in a middle school and some of these kids would not waste their time on something this inane. or maybe a better term would be insane. good day and good luck.
what DA is trying to say is. BALANCE THEM. Not the 4.10v per cell but the 4.20 per cell. I always test my cells before using them and after a dozen or so cycles. The new packs you bought had some way out cells.DrkAngel said:LC ...
Did you ever get yor new cells balanced?
Better test them, to make sure they're usable.
Both packs having a cell way out of whack is a pretty bad sign!
DrkAngel said:If you really want a short length bike, with cargo capability ...
Should be perfect for you ... since you don't like front brakes anyhow?
Just leave the shopping cart in the front yard ... and carry bike, with no front wheel, up stairs?
"Self discharge" indicates a bad cell with no fix except replacement.
Poor capacity cell can be "helped" by adding a small cell in parallel.
No frills, no safeties with pot throttle built in ... but can be externalized.
Looks like exactly what your looking for, not recommended but when has that ever stopped you.
It's just a shame that YOU don't read what is posted.DrkAngel said:Charge all cells to a balanced (equal) ~4.20V
iMax " LiPo Balance" is typically 4.17V.
Confirm all cells equal!
Let set several days to diagnose for self discharge. (Cell or cells with decreased voltage)
"Discharge" pack, with iMax or any other device - recommend cell level voltage-alarm device @ < $2.
Compare cell level voltages for comparative capacity.
Any unequal capacity pack or pack with self-discharge should be returned to manufacturer for replacement!
Pack capacity is only as good as weakest cell.
I see cell balancers not the balance CHARGER.
You can balance any shitty pack at lower voltage as you are doing with the cell tester. I can take the garbage I'm discarding and balance it at the 3.85 but maybe not the 4.20v,
Yes, this is a hobby for most of us but we still like what we build to be RELIABLE. Being able to jump on my bike and go to a store and not to worry if I will make it back.
It's so hard to believe that you, YES YOU are as stubborn as my DOG. I tell her to use FLUX and all she does is give a blank look. That is what it seems to be happening here with almost everything.
