LC, I think you know what 2p,4p and 6p means. You are saying that a 6p Samsung was rated at 4;4Ah? Wow, you must get some real fake cells to be that bad. I bet Dura Cells would do better.
No that is not what I meant.
Skalabala I think recommended them I think. They were 2P - 20 Genuine Samsung cells hooked to a BMS and rated at 4.4 Ah.
I ordered four for 8P. One was 2V lower than the others so ran it by itself to see what would happen and did not even make it a mile on flat at 10 mph so I tried to send it back and got a partial refund instead.
I ran 6P Samsung for over 3 years now. The SONA packs I ordered about 6 months before the Samsung which were also 4.4 Ah-2P.
I ordered two of those for 4P. All those old packs are finally in parallel now. I did that yesterday.
The new pack was 4P to start for 175 bucks. It might be a fake but do not feel like sending it back. Instead I will come up with a way to ventilate it and will hook it in parallel to two - 2P - 4.4Ah packs I ordered last night that boast Genuine Samsung cells.
So the old packs that are in parallel now are rated at 4.4 Ah * 6 = 26.4Ah. However since they have been run at 4P and 6P separately their entire life it is safe to say they are about 50% original capacity or approximately 13 Ah.
When I get the two new packs for 8P that will be 4.4 * 2 = 8.8Ah + the fake cells which are rated at 14 Ah but probably closer to 7 Ah if they are Fake cells so am looking at 8.8 Ah + 7 = 15.8Ah but will call it 15 Ah.
That is important as if the old packs which are 13 Ah @ 50% capacity then on long distance I can safely say if the old packs get me to a destination then the new packs should get me back home.
The multi meter I have is old and does not stay calibrated. It is all over the place and eligible for the bone yard. :lol:
I am looking at doing this. Would it work. I would need the extra bullets though to unplug the meter so it can be calibrated from time to time so need to buy two identical meters and a pack of 9V batteries to power and calibrate them. Would that work for a battery gauge ?
The bottom pic is another idea to improve overall battery life as heat is the enemy. It will require a separate 12V battery and two high speed/output fans.
I ordered a pack of 5 bullets and the new 4P pack has bullets so will need 3 more bullets to do that. I will need to throw 20 or 30 bucks in my account from a different account as there is not much left in there now. I may as well order a second pack of 5 bullets so I have a couple extra. If these 2P - 4.4Ah packs are worth it I will be ordering a lot of them.
In fact the battery gauge will give me a good idea of each packs capacity as can run each of the 2P Samsung packs separate on the flat for about 5 miles at the same speed and then the 4P - pack the same speed and distance and compare the voltage. If the voltage is the same for the 2P packs as the 4P pack then I will know the 4P pack is Fake and the 2P packs are genuine. That method would also give me a general idea how much capacity the 100 old cells in parallel has.
In the bottom pic the PVC coming in will be smaller than the PVC going out. It would be where the wires come out to the controller but not much larger so it does not pull in a lot of hot air. The fan would not need to be large either or move a lot of air. The idea is to move the heat out NOT blow a lot of hot air in. The wood brace will keep batteries from moving up and down when hitting bumps.
Please let me know if that could work. Thanks.
LC. out.
