latecurtis
Yes. It is standard with e bikling motor kits to have a module which mounts to the bike handle bars. it turns the controller on and of.
However.
That is not the case though with 5 other e bikes I have in storage in NY. I experiment with chain drive e bikes. I even have a 20" e bike with a 500W 2,500 rpm - 24V motor on the back with an 80T freewheel sprocket and an 800W 36V motor on the front that is running 24V and has an 56 tooth spoke sprocket on the front. The rear is #25 chain and the front #40 chain. @ 24V the gearing is about 1.5 MPH difference or less than 2mph so the motors basically work together for approx. 20 mph.
I have run both motors at 36V and 30 mph but 24V is better gearing for up hills. Those bikes do NOT have the separate module and also are brushed motors and controllers.
I am going to put money in my account to place another order today for the Meter DA. posted and a better switch. I might get that DC breaker you posted. I also will need more bullet connecters.
My other bikes in NY are Easy Street named after the song from the Walking Dead. It is a 700c Giant Cypress hybrid and It has the same motor as what I have here and the module on the handle bars.
Then there is a 750W 36V gear reduction chain drive and a 1,000W 26" front hub kit and an 800W 20" front hub kit. I do not remember if those two hub motors have the module like the e bikeling kits but do not think so.
Thanks.
LC. out.
However.
Thanks.
LC. out.
