the wires from the 24V controller are two red and two black.
DAND214 said:You are correctSkalabala said:latecurtis said:http://www.amazon.com/AmpFlow-A28-400-Brushed-Electric-Motor/dp/B00AG21RUE/ref=sr_1_8?ie=UTF8&qid=1438201992&sr=8-8&keywords=AmpFlow
This is the motor I really want for the 20" bike
It would do 45mph with a 70 tooth sprocket on a 20" wheel with the 11 tooth motor sprocket![]()
I wish I had money like that. Thanks
LC out.
Looks like a brushed motor?AmpFlow A28-400 Brushed Electric Motor, 12V, 24V or 36 VDC, 4900 rpm
Dan
You might want to open the controller and see what's in there, sounds more like just a relay for on and off.
Do you ever read what people post or don't care?
Save as complete web pages and read when you get home ... just takes a couple clicks and you get hours of research-reading.latecurtis said:The problem is I don't have enough time online to research stuff I just have enough time to order things. That is why I do all my long posts at home and put them on a flash drive. LC out.
Well 1st ... again! ... look for a wheel or a hub, not a rim.latecurtis said:I still don't know what a bike rim with a freewheel on each side is called. It is not flip flop as the freewheel on the opposite side of the pedal freewheel needs to turn counter clockwise to work. LC out.
Get the model # of the controllerDrkAngel said:Depends on if it is a match for whatever controller.
E.G. Hall to hall
