DrkAngel
1 GW
I already did a sprocket size for a 5000 rpm motor you decided on.
26" - 7000 * 11 / 256 = 300rpm ... 23mphDrkAngel said:1. motor rpm x motor sprocket ÷ wheel sprocket = wheel rpm (revolutions per minute)
3000 x 9 ÷ 90 = 300rpm
2. wheel size" x 3.14 ÷ 12" ÷ 5280' = mpr (miles per revolution)
26 x 3.14 ÷ 12 ÷ 5280 = .00128 mpr (miles per revolution)
3. rpm (revolutions per minute) x mpr (miles per revolution) = mpm (miles per minute) x 60 minutes = mph (miles per hour)
300 x .00128 = .38655 x 60 = 23.19mph
Think I got the math right ... ?
Haven't had coffee yet tho!
Should work and give good efficiency, (modest heat production), ... if you keep above 15mph on hills!
1500w will only push you along at 35mph maximum on good level ground.DrkAngel said:26" - 7000 * 11 / 256 = 300rpm ... 23mphDrkAngel said:1. motor rpm x motor sprocket ÷ wheel sprocket = wheel rpm (revolutions per minute)
20" - 7000 * 11 / 197 = 300rpm ... 23mph
20" - 7000 * 11 / 100 = 600rpm ... 45mph
45mph requires 3200w motor tho ...
DrkAngel said:3kWh output = ...
6000w input ÷ 48V = 125Amps from a 9Ah battery ... ouch!
Enough power to run 6 1000w heaters ... for a couple minutes ... then ... buy new lipo for next mile ... maybe 2!
I prefer getting decent range at reasonable speed rather than getting almost nowhere fast.DrkAngel said:Either motor - cruising speed.
For LiPo: x.66 for each 5mph increase.
44.4V 9Ah(measured capacity) =
10mph = 35 miles range
15mph = 24 miles range
20mph = 16 miles range
25mph = 10 miles range
30mph = 6.5 miles range
Figured for level travel ... no hills ... for either bike.
35mph = 4.29 miles range
40mph = 2.83 miles range
45mph = 1.86 miles range
50mph = 1.23 miles range
55mph = .81 miles range
