latecurtis
Well I am glad to hear from you. I just won my first race against a gas powered bike Saturday evening and the hub motor kit you sent me was on the back with a 1,000W brush chain drive on the front so together they out run the gas bike for a short distance. About 250 to 300 feet I think. Not sure. It was a parking lot and raced two light poles. I posted the video but was far away so not clear but shows I was way ahead at start of the race. It proves my point that two motors is better than one as doubt either motor would have won running solo.
I know I am good with windows paint but never used CAD. I am not familiar with it but will definably check it out. My first 3D print project if I get one is building solderless cell holders for 18650 cells. I have about 200 or so cells and interested in ordering more for a couple 10S - 6P packs and a 13S - 10P and a 16S - 20P pack. Tomorrow when the liquid electric tape is dry I will wrap regular electric tape over the top of the bolts top and bottom. then a piece of gorilla tape so that there is no way a bolt can loosen up. Each connection was tested several times before wrapping the wire around the bolts. They will stack on top each other with no chance of shorting out.
I have been using corner molding which is a couple bucks a foot and small nuts and bolts , Gorilla glue and hot glue. zip ties and electrical tape. That is my first 1S - 6P pack. 9 more to go for 10S - 6P and have a BMS to hook up to it. The pictures in my previous post shows how I counter sunk the nuts in the wood. the picture below shows the top nut. I probably did not need two nuts but wrapped wire around the bolt so the second nut is to keep the connection firm.
I want to 3D print plastic holders and have the holes threaded if possible. I wont need as many nuts. Also should not require expensive filler material as wont be under high stress situations.
thanks and hope you can post again soon.
LC. out.
LC. out.
