Turbomatic
New-ish here
- Joined
- Nov 14, 2014
- Messages
- 40
Xtr6 said:Got one off the last F24 and it was running fine on the new bike. Changed the motor and wanted to import a file but since then he doesn't do anything. In the display i run to the auto setup for throthle and brake and that went just fine but in the auto mode in the controller I got no throtle and no brake only error.
What is happening is it in secure mode????
Probably in your controller the new firmware. If the throttle and brake levers are connected to the On-board computer, then they must be configured in the section menu On-board computer > Control setup. In this case, when starting the function Full setup, you must skip the menu items Brake and Throttle (they will be detected as an error) or you can not start Full setup and activate each setup menu item manually starting with Motor LR, then Motor and Angle correction.
