Ianhill
- Joined
- Sep 25, 2015
- Messages
- 2,871
What i see is the loss of chain tension fighting the suspension from a cradled motor design being changed to the mass added to the swing arm, the motor can either be on the swing arm pivot making its levering effect in the swing arm least as possible or it can be positioned in a cradle to keep the weight centred and low as practically possible.
There is benefit like mentioned a less complicated chain setup less length and no real tensioner needed just wheel adjustment to pull chain to correct tension
Chain tension and cogging of the wheel acting on the suspension and wheel weights etc is a big deal to how fast you can comfortably control your bike downhill, professional downhill bikes use a blank last gear and extremely strong light wheels they select the last gear so there's no peddle effect on the drivetrain this allows the suspension to move more freely, same happens on a motor bike if the motor is a cradle design if the chain snaps the bikes suspension feels free if your lucky enough to coast home.
Point being the rear end is worth seconds on a downhill section where on a road bike not so much it depends how and where u ride if you need the extra or not.
