Hillhater
100 TW
extremegreenmachine said:..One thing is the 9c needed to fly up that hill to keep its momentum...
..and its small dia wheels helped a lot too .. remember that when you are planning your "bad ass" hub motor build.
Hillhater said:extremegreenmachine said:..One thing is the 9c needed to fly up that hill to keep its momentum...
Hillhater said:knoxie said:....The Rohloff geared hub is a definite score! they are amazing and with the Opti its the only option to avoid the chain slipping under heavy load..
how does the choice of hub make any difference to the chain slipping ??
Hillhater said:Ok, i get where you are coming from,... but i dont see Rohloff as the ONLY option .
the are several other IG hubs and the Nuvinci that would also serve the same function
extremegreenmachine said:Does anyone know a way to measure steepness...so i could say this is 25 percent grade...etc?
Optibike chose the rohloff for all the reasons already mentioned my post was simply inferring that the only option was to fit a geared hub, its an expensive unit but it its the very best, they are as smooth as butter and easily cope with the power of the Opti, the nuvinci has been unreliable on some drive setups and other geared hubs have snapped pawls and all sorts, Opti pitches itself at the high end and dont compromise on quality.Hillhater said:Ok, i get where you are coming from,... but i dont see Rohloff as the ONLY option .
extremegreenmachine said:Maybe something is wrong with my bike...
By the way my bike has the plastic gears as well...i am just use to quieter ebikes.
extremegreenmachine said:I am getting flamed in another thread for my hill climbing videos being lame. He thinks i should take them down because even with bad knees he could beat us up these hills with just pedaling which is just BS.
We realized right after we shot them that the video did not do justice to how steep these hills were. For that reason i tried to explain in the thread how steep it was.
Does anyone have an idea how to capture steepness of a hill in video?
extremegreenmachine said:..Does anyone know a way to measure steepness...so i could say this is 25 percent grade...etc?
Absolutely!extremegreenmachine said:But if your looking for good hill climber...consider 20" tire.
