Green Machine
There are just so many factors in a ebike race. I think that is the reason ebike races always seem to be blowouts.
I think there are more and bigger factors other than the tire size.
How many watts your pumping, how much your bike weighs, how good of a peddler is the rider?
First regarding the rider...notice in the pictures the bmx has no chain...so the bmx won the race with no peddling. I have heard a good peddler is worth 500 watts...i am probably putting out 200 watts only
Also rider weight is a big factor. A 100lb rider will do much better in a hill climb...and the bmx rider looked really skinny.
Regarding weight...the bmx looks lightweight but its atleast 80 lbs in the pictured configuration. The opti with equal amp hours is 55lbs. I rode the bmx and it is a very jarring uncomfortable ride off road being so heavy with no suspension. It is really the opposite of the optibike which is a very smooth balanced ride even on very rugged terrain. Remember the optibike has lightweight wheels...so it dos not have any unsprung weight on the wheels which is detrimental to ride feel. A weight class wouldnt be a bad idea for an ebike race.
The biggest factor to me is wattage. The optibike does its thing at 850 watts...the bmx 3000 watts. For a race to be fair it would be have to be divided by "watt class". This is the big one in my mind and the reason why i have never seen a "close" ebike race for any substantial distance.
For the record, i see no way a hub motor could compete if limited to 850 watts because of the efficient nature of the 14 speed rohloff in the mid drive equation. If a hub motor could win limited to 850 watts i would forever be sold on hub motors seeing no advantage at all in mid drives except for weight balance.
The last factor is the optibike is not really designed to race up the hill as it is just to get up it safely and dependably. The hub motors need to build momentum and speed before they can climb....the opti can comfortably climb at 3mph. Perhaps if i could find a steeper hill to race the opti will crush...just a guess. Also if the hill were more technical it would be too difficult to race up at 10 mph hub motor speed.
