mingonn said:Hi jha07,
You are not alone buddy, I am in the same boat with 2 suspect cells. Waiting for replacements from Ping at the moment. All symptoms sound the same, false peak by the weak cells then upto an hour of requent pulsing (on/off) by the charger as the BMS trys to balance the pack. Weak cells then self discharge or drop voltage over time to around 3.4. I am suspect the weak cells cause the BMS LV cut out to trigger well before the remaining cells get close to the low voltage cutout.
Have tried all Pings suggestions, leaving it charging for 24 hours, individual cell charging with my RC charger (3.6 cut out) but it made no difference, on the cycle program with 1A discharge to 2v I only get around 1500 ma.
Pretty frustrating after reading all the good reports from everyone else, even more so considering my cheepo 4 ah lipo rc pack has faithfully churned out 1000 km now withou a glitch and cells have remained within .01 of a volt with out balancing.
My wife commutes with the Ping pack and is busting my nuts to get it sorted, only 600 km on the clock so far (6 amp current limited)
Will let you know when the cells arrive
Cheers
Derek
Well, I guess I feel a bit better that I'm not the only one having problems. My replacement cells arrived a few days ago and I have them replaced now. Of course the new cells are not at the same charge level as the others, so I'm trying to charge the new cells up to the same level now. I will know soon if all is good or not.
It is pretty frustrating having problems with a pack that is so new. I had maybe 15 cycles on mine before I noticed the balance problem. On top of that, my pack didn't even work when I first got it. It was due to another bad cell. So I'm really hoping the rest of these cells don't give me any more problems.
