lbz5mc12
Yesterday on the way to the store going uphill against the wind I think my motor burned out. It's a 24V 250W currie motor. At first I thought it was the battery or controller. I recently switched out the currie controller and throttle for a 24-60V scooter controller and throttle. I was using a 36V controller and throttle with a 36V BMS battery pack. So I hooked up the currie controller again and I got a green light on the throttle indicator so I turned the throttle. The motor engaged for a couple of seconds then it sounded kind of rough, the light on the throttle went to red flickered and went out and then It smelled like something was burning. I determined that the smell was coming from the motor. I have a spare 36V motor of the same type so I hooked it up to the universal controller and it worked fine. Then I tried out the currie controller, the green light came on on the throttle but the motor wouldn't engage. So I think that somehow when the 24V motor died it took the 36V currie controller with it. I also hooked everything up to a different battery pack and had the same results all around so at least my BMS battery didn't get fragged. Another problem is that a can't seem to get the nut loose that holds the gear on the motor so that I can have a looksy inside to determine what happened.
