e-beach said:... screw ...
Screws cut threads, and they are stress risers.
Carefully drilled 3.2mm holes and pop-rivets don't. It's why they use pop-rivets to hold aluminium planes together.
Buk___ said:.....
e-beach said:Buk___ said:.....
Hummm......Looks like I will have to dig deep into the ole tool box and look for my pop rivet gun.
You know that steel work hardens. It's why we cold forge things. And we all know that steel fatigues because we see bikes and other objects that have cracked that way.Buk___ said:Every time I mention "Al has no fatigue limit", you say: "All structural metals work harden; all of them fatigue." which is a fundamental mis-statement of the facts.
If a steel structure is design such that its expected maximum loading + some margin is less than the fatigue limit, it will not fatigue. Ever. (for all practical purposes.
Aluminium has no fatigue limit. If you cycle it enough times, it will always fail no matter how beefy you make it!
.If you project a 10 year lifespan and design an aluminium bike frame to suffer orangutan-ing force levels, then you'd have to make it so beefy that there would be little or no savings over a steel frame constructed to the same specifications. And the steel frame would go on indefinitely barring accident or corrosion.
Chalo said:Weight for weight,
Buk___ said:liveforphysics said:It would only be useful if all joints were designed around being adhesive bonded joints, then it would be fine.
For something like fixing a head tube, it would just fail, as the aluminum failed with that loading and the metal that cracked was bonded as well to itself as you're going to get from that design.
The beauty of the casting tape is it added a very tough resin to a very tough fiber material, so once you've built adequate layers of it, it's now redesigned the joint to be well supported by the fiber composite structure alone (aka, wrap until it builds up some bulk the high stress areas).
Buk___ said:liveforphysics said:Broken bone casting tape is amazing stuff. ... I would trust it more than I trust welds in aluminum.
How do you feel about heat-cured epoxy-bonded Al?
I was thinking about forming a roughly u-shaped piece of (say) 0.8mm Al around the tube to span the crack and then heat-set epoxy it in place; then put small (say 3mm) pop rivets in the top corners plate both sides as an anti-peal measure.
But he would have to strip back the paint and oxide on the frame first.
speedmd said:Don't band aid the frame. If you want to just fix it, you want to weld it and add lots of material (fillets) to cover much further out onto the tubes. I would fold a section of aluminum sheet and add it as a gusset also that connects the top down and head tube to it also. ...
e-beach said:@LPF, Thanks for the welding offer, but getting up to SC from LA is a bit messy at the moment with the 101 closed, horrific mud slides and all. However the urethane casting tape sounds fun. I mean, if this frame is going to be put to pasture, a cheap fix for the purpose of having a peddle bike for short local runs or when I feel like taking the flat streets to the beach. I just might do that fix.
What I would probably do is wire brush the whole area clean of dirt, paint ect. Clean with acetone. Then, on both sides, screw and epoxy a small steel plate that spans both sides of the crack to keep the frame from separating at the crack, (one screw or bolt on either side of the crack, 4 fasteners total) and then apply the casting tape. Finish with paint and she would be ready for peddling pleasure. Could probably be done for under $25.00 usa.
liveforphysics said:........I'm actually doing grid-tie battery development for a client in LA right now .....
Just PMed you
Chalo said:If a steel structure is design such that its expected maximum loading + some margin is less than the fatigue limit, it will not fatigue. Ever. (for all practical purposes.
To the nearest approximation, bike frames are not built that heavy. Ever.
If you're re-welding aluminum that's already been welded and heat-treated, you've already lost the game.
Buk___ said:So you are saying that no steel bicycle frames are built to withstand 250MPa stresses?
Chalo said:And there are two reasons I can't give a definitive answer to that question.
First is, even though a frame can be characterized by stress analysis, the stresses it will see out in the world are not easy to characterize or quantify. What are normal forces for one rider are abnormal for another. So what constitutes "normal forces" pretty much has to include most of the ugly end of the bell curve.
Second is, I don't know what the stress levels are in any units, by any form of direct measurement.
liveforphysics said:I've personally never felt like pedaling related forces were significant compared to riding impact related forces.
Buk___ said:[...]well below the 480Mpa fatigue limit of normalised ChroMoly.
Chalo said:Buk___ said:[...]well below the 480Mpa fatigue limit of normalised ChroMoly.
That's close to the yield stress of normalized 4130, so the fatigue limit would be not much more than half that.
Chalo said:liveforphysics said:I've personally never felt like pedaling related forces were significant compared to riding impact related forces.
Right. Potholes and even little bumps can have much higher instantaneous peaks (even if the durations are short),
Buk___ said:Chalo said:liveforphysics said:I've personally never felt like pedaling related forces were significant compared to riding impact related forces.
Still missing the point. You don't generally ride from one pothole to the next. Most of us try to avoid them.
A commuter: 1 hr a day at an average cadence of say 45rpm.
45*60*5*48*2 == 1.3 million flex cycles/year. This is what kills Al frames!
Maybe he cannot avoid 1 pothole a week. 48/year. So long as they don't exceed the yield strength, no harm done.
liveforphysics said:Even on my road bike, I look for the biggest sets of stairs to drop or climb, and ride over log piles and aggressive downhill trails, and it still feels like inadquate training for cyclocross racing.
For that reason my roadbike is cromoly, and the frame has not yet broken (though I go through wheels faster than most folks go through tires).
Buk___ said:liveforphysics said:Even on my road bike, I look for the biggest sets of stairs to drop or climb, and ride over log piles and aggressive downhill trails, and it still feels like inadquate training for cyclocross racing.
And presumably isn't a 1.5kg racing frame with eggshell thin tubes.
liveforphysics said:It's a 2002 Lemond Zurich using Reynolds 853 (the predecessor of the amazing 953) running a mix of dura-ace components with a cable pull ratio modified modern XTR rear derailleur (for it's auto-chain tensioner function that is awesome for avoiding chain drama on big impacts).
The tubes are butted to leave just the ends where the weld joints happen to be thicker material, and I bet the mid sections of the tubes gives egg-shell a run for it's money at some point, as it's lighter than my friends carbon road bikes.
