DaDo.Bzz
Regular
- Joined
- Feb 12, 2015
- Messages
- 251
I did some experiments with params and this are my findings.
What is important is Designated Assist param for Pedal and Throtle assist. It will override Basic tab params including speed limit (doesnt matter what PASS you select on display) Then it takes current and speed limit param from the row you selected in Designated Assist field.
So best is to leave Basic and Pedal assist on default. If you need quicker response to pedalling lower Startup degree ( min 2, does not work on 1) and Time of stop ( I set it to 10=100ms).
To have full power for throttle on each PASS change Designated assist to 9, Mode:Current, Start up current: 3% (to have 3% power on begining of thrtotle) Speed limit: By display
Better to set lover Designated assist, not to go still on full power as you can overheat motor and FETs, So change it to 6 (73% of max power) and set on Basic tab for Assist 6 speed limit 100 to get full speed. When you select 5 mode PASS level on LCD row 6 is never chosen as then it takes rows 0,1,3,5,7,9 from basic tab for Pedal assist.
Speed limit is limit of max rpm of crank, not the param max speed set on display.
