Hello all, since winter is here and I find myself riding in the dark more I have considered putting an ebike light on my tsdz2 mid motor build. This Lezyne 800 high voltage looks like it is up to the task. https://ride.lezyne.com/collections...cts/ebike-lite-pro-drive-800-switch-high-volt
Reading the manual brings up some questions though. Can I wire this in parallel between my 48v battery and the motor? The light is designed for motors like bosch and it says it should be wired into the motor.
Will the light dim if I use full assist? I mostly use 1 or 2 PAS and and on occasion use 3 or 4 PAS.
My battery does not have an off switch and the manual mentions avoiding deep discharge, does the BMS that comes in batteries automatically switch off the battery if it drops below a certain voltage? I typically take my battery off and charge it after a ride but I want to know just in case I forget.
Regards
on a side note I bought a cheapo ebike light last year but it wasn't bright at all and just resorted to using a small flashing light on my person which is fine most of the time in a well lit city but occasionally there are dark spots.
Regards
