Hello, I have an extra QS205 V3 hub motor that was giving me a 0000008 fault code in my Votl tuning software.
A few months back I had accidentally spliced through a phase wire with the brake rotor. Seemed to fix it ok as it worked for a while. Then stopped again.
Took the motor apart this morning and noticed one of the hall sensors actually detached itself from the circuit board.
Is there a way to re-solder these sensors directly to the wiring instead of using the circuit board?
There’s also an extra red and black wire that go inside the coil windings and not sure what they do? The extra long black wire went to the other side board but that board is no longer connected….long story.
I attached some pictures. Maybe it’s best to just get a new board and sensors?
Thanks!
Thanks!
