QS Motor 205 50H V3 Electric high power bicycle kit / E bike kit / spoke hub Motor 3000W Powerful Hub Motor Kit with TFT H6 speed meter
For 205 3000W 205 V3 electric spoke hub Motor kit assembly, it could be used for high power electric bike, which could be 72V 70KPH.
e.g. Electric high power bike
E-bike weight, approx 47kg+80kg
Tire diameter: 2.50-19
Speed: 72V 70km/h
Climbing slope: 25°@127kg
Battery: 72V40h lithium battery
One set including below kits
1.1pc X QSMOTOR 3000W 205 50H V3 electric spoke hub Motor
2. 1pc X Motor Spacer
3. 1pc X Freewheel
4. 1set X 19X1.6inch moped front wheel and 19X1.6inch rear wheel
4. 1pc X Sabvoton 72150 controller (customized for TFT speedometer) with bluetooth adapter
5. 1pc X H6 speedometer
6. 1pc X Half Twist Throttle
7. 1pc X Thumb Throttle
8. 1pc X disc brake assembly
9. 1pc X DC DC converter 72v to 12V 10A
10.1pc X PAS
1. Motor
Test report:
2. Motor Spacer
To protect motor phase wire
3.Freewheel
General SPEC
1. Single speed 1/2*3/32*16T, only 16T is available now
2. Black
3. English System Thread
4. Suit for QS Spoke Motor (English thread)
4.19X1.6inch moped front wheel and 19X1.6inch rear wheel
1.60X19inch 2 Cross Pattern Moped Front Wheel Set
32X10G Spoke, silver color (Iron with zinc coat)
32 holes, 110mm dropouts, black
1.60X19inch 1 Cross Pattern Moped Rear Wheel Set
36X10G Spoke, silver color (Iron with zinc coat)
QS 3000W 205 50H Hub Motor, 36 holes, 150mm dropouts, black (not include motor)
5.Sabvoton 72150 motor controller (customized for H6 speedometer)
Product Description of Controller
1. Generally SPEC
1). sine wave controller, programmable, with regen function
2). DC Current Limit: 150A
3). Max. Phase Current: 350A
4). Protect Phase Current: 450A
5). Battery Voltage: 24V-72V rated, Max. 95V
6). Including one controller
7). controller size: 247mm*146mm*62mm
8). Net weight: 2kg
9). Default including bluetooth adapter.
10). Default function: Hall, Throttle, Electric brake, High Brake Level, speed switch
11). Special functions: Waterproof
PS. Please note there is no temp sensor for motor.
6.TFT H6 color speedometer display
SPEC
· 3.2 inch color TFT screen
· 48V/60V/72V power supply
· Shutdown leakage current <1Ua
· Supply controller terminal operating current 100mA
· Normal operating temperature of the instrument -20~65°C
Function
1.Battery display: 5 segments of power indication, the voltage value of each segment can be set according to customer requirements;
2.Speed mode: real-time speed RT SPEED, maximum speed MAX SPEED, average speed AVG SPEED;
3.Speed display: display range 00.0. ~ 99.9, unit Km / h km per hour, MPH miles per hour;
4.Assist gear position: 0~9 files, of which 0 gear is neutral and no boost, 1~9 corresponds to boost gear, and P is displayed in 6Km push mode;
5.Headlight display: displayed when the headlights are on;
6.motor temperature: monitor motor temperature in real time;
7.Mileage mode: cumulative mileage ODO, single mileage Trip
8.WH.KM: the controller power consumption ,wh/km
9.Motor temperature.
10.Regen Ah:Cumulative Ah while controller in regen mode .
11. Clock: Built-in battery, user set up;
12. Clock: Built-in battery, user set the year, month, day, hour, minute and second.
7.Half Twist Throttle with 3 speed toggle switch
8. Thumb Throttle for 0-5V variable regen brake
It could be mounted in left hand
9.Disc brake assembly
electric bicycle aluminum hydraulic disc brake system assembly
Specification:
1. Model: 152PYD+BS150
2. Including 2pcs 203mm plate, PCD6*44mm, 2mm thickness
3. The length of oil of both front and rear can be customized according to your e-bike(900mm for front, 1600mm for rear as default)
4. Callipers: double-piston 2*21mm
5. Installing Distance of front tire: 74mm(as default) or 51mm
6. Installing distance of rear tire: 51mm
7. Wiring: two core wiring
8. Materials: Caliper/Lever Cast aluminum, Bracket: Cast aluminum
9.Current: 1A (max)
10.DC DC converter
72V to 12V, 10A
11.PAS
Made of steel material, durable and reliable.
Mount on electric bicycle pedal, easy to install
1:1 power assist, make cycling easier and funnier.
Suitable for most of electric bicycles.
More details, see this link: https://www.alibaba.com/product-detail/QS-3000W-205-50H-V3-e_62238821212.html?spm=a2747.manage.0.0.5a3e71d2yR87IY
Thank you,
Judy
E-mail: judy@tzquanshun.com
Skype: judy.gong5
