izeman
1 GW
oh man. putting YAW and ROLL on the correct sides makes flying MUCH easier
i had THROTTLE + ROLL and YAW + PITCH together!
that must have been the cause why i couldn't adjust settings with my sticks. sure. if they are mixed up it can't work.
i should have started to think because i had to change the default
to
to make arming work. all those beginners problems you can run into!!!
now i can calibrate ACC with my sticks as well (LOWER LEFT + DOWN)
still flying needs a lot of training. throttle eg is VERY aggressive. i set MID=0.20 and EXPO=0.00 but i'd like to smooth the throttle a bit.
Code:
#define ALLOW_ARM_DISARM_VIA_TX_YAW
Code:
#define ALLOW_ARM_DISARM_VIA_TX_ROLL
