Rix
100 TW
Merlin said::-D
Her first time...
[youtube]GzxxNsMH1NM[/youtube]
Very fast. Glad the crash wasnt to serious. But still, crashing sucks.
Merlin said::-D
Her first time...
marcn said:Thanks Merlin,
I was thinking of doing what Snell did, and running a 3 switch to control wattage, and then another 3 switch to control speed. Although not exactly like a one switch poti to control PAS, it could mean it's safer. That way you could just use autopas and have the controller 3 speed switch limit watts, up to 60A for example in increments of 20A, so even with AutoPAS through the CA, there's no unexpected surprises. Then use the throttle override for full power.
Though I like your poti a lot. Could you give some details on that and how you wired it?
Mammalian04 said:He also has a switch that limits the speed of the bike. I think he has it set to zero (disables throttle), then 2 other speeds. I think this is a great idea. He implemented the Zero because people often walk up to bikes (or motorcycles) and twist the throttle for no reason at all. On a motorcycle, people are smart enough not to do that when the engine is running but on an e-bike, they have no aural indication that the motor is "on."
Merlin said:sure, i will do...when you tell me how to hold a camera at 110kph or a WOT with 12kw on accelerate![]()
Offroader said:Thanks Merlin. I was thinking about how these single speed chain tensioners would work because you would need the perfect distance from where the tensioner attaches to the bike to where the freewheel is.
I thought maybe you could move the freewheel a little bit with shims to get it to fit.
The shimano zee derailleur looks really nice. I like the fact that it is short. The problem I am having is I keep hitting my derailleur on rocks and stuff.
I guess a derailleur is the way to go as you can adjust it to fit the chain perfectly. It is also a clutch type which are supposedly the best.
I'm currently in the process of completely renewing my whole chain, chainring, and chain tensioner.
Merlin said:...§(%§(%"(/"§$"%)$% Fu*******
....the poti is from cycle-analyst.de
http://www.cycle-analyst.de/Cycle_Analyst_V3_Potentiometer_Deutsch.html
(i took the easy way ;P)
