dirttorpedo
- Joined
- Mar 21, 2017
- Messages
- 53
So I finally got around to setting up my Kepler Drive commuter this weekend and I think I killed 2 VESCs. I'm using an FOCBOX and a Turnigy 6354 260kv. I plugged in one phase wire and as soon as I got the second one in the motor started twitching and suddenly stopped. In BLDC Tool I'm getting detection fails on some things and not others. I can see in ADC programming that my throttle is working properly, it's just not powering the motor.
Now the really dumb part. I tested the the phases on the FOCBOX and the middle one tests like there's a bad FET. I ASSumed the controller was the issue since I picked it up on ES. I tested the phases and I plugged in a second FOCBOX. This time the motor made a high pitched whine for a second when the second phase was plugged in. I pulled it out quick but not quick enough. Now it's behaving the same as the first FBOX.
So I'm pretty sure the motor has a short somewhere, even though it's brand new, but I'm not positive. How do I test this? How easy is it to take apart? Is it just the little c-clip on the shaft? And while I'm at it, does anyone know if there anyone around doing VESC repairs?
