fizzit
Hi, I'm just wondering if there is a market for a small, simple device that converts the 0-5v signal from a pot or hall throttle into the pulses required by RC motor ESCs.
Here's my proposed feature list:
-Small size (1" by 2" max, hopefully)
-Reliability
-Motor cutoff when brake applied
-Temp probe included for cutoff (that you can unplug and choose to not use. maybe have temp cutoff adjustable by trimpot)
-Easy calibration / set up (hold button and twist throttle to calibrate, idea used with permission from fechter)
-Optional Safety cutoff (when the throttle voltage goes above the max voltage calibrated, which is what often happens when a hall throttle breaks, the power will cut off)
-Indicator LED
-Up to 100v accepted
Possible other stuff:
Throttle curve to reduce sync loss
Tach measurements (to tell when to activate, therefore reducing sync loss)
The temp probe could also be replaced by a shunt, because the MCU will just look for when voltage received on the ADC channel (which will be scale-able by a pot) goes above a set level.
I'm thinking of selling it for about $40. Is this too high? Are there any other features you would like to see? Any feedback is appreciated.
PS. I think this might go along with the kepler drive well
-Reliability
-Indicator LED
