Ariane
novembersierra28 said:Believe me, I would if it would be efficient (if I could get 200km like DocB did, out of twin agni's, I would.
5305 is a very efficient motor, the 9c is a little bit more efficient but less powerful, either one is a pretty good choice.
in the case of the twin 5305 the parts can be easily sold onwards, I don't want to face up to the possibility of selling it all for 1/5th of the price, in fact, the twin 9c would be a blitzer.
For now I am following methods route for the thrill ride, it is the next level after the 2wd > etek
actually, correctly phrasing it, 'my' etek is slow, the insane-a-cycle with motorcycle chain on the hub and 450amp controller with 0 ramp is probably as fast as the 2wd kit. But you have to change the chain every 500 miles :\
we will see what else can be built.
BlackArrow said:novembersierra28 said:I was toying with the iea of first building a twin 5305 setup, front and rear...to run on 100volts...but the setup was so heavy, i counted it would be over 55kg of kit.
I have an idea for you instead of using dual X5, just use (2) Agni 95 R motor at 96 Volt (each) with Nano Lipo on a custom ebike frame of course you can put a biggertire on the rear wheel for a sort of drag ebike. And i'm really confident that you got something like 70 HP (real) on the rear wheel with a dyno test 8) that's serious power and now we are talking![]()
Good day!
Black Arrow
This post is really too funny :lol: a single Agni 95 R is sufficient to beat Doc if it's your goal and this motor is one of the more efficient motor on earth with this kind of power, is more efficient than your actual Etek for the same weight, it can take with 400 Amps peak and 200 Amp continuous at 84 Volt 200 Km/h where did you have find this
Good day !
Black Arrow
