Hillhater
100 TW
Have you seen other tests on these cells ?
Here is one such, on this forum.. https://endless-sphere.com/forums/viewtopic.php?f=14&t=91926
It fairly clear from those tests that the full 4800mAh iis available , but there is very little between 4.2-4.1 volts (350mAh ?). And less in the 2.9 - 2.5 volt range (200mAh)
And here the test only ran to 2.8 v cut off, but still discharged over 4700mAh
http://lygte-info.dk/review/batteries2012/Samsung%20INR21700-48G%204800mAh%20(Gray)%20UK.html
So , run your 4.2-2.5 volt discharge test, then compare results and test methods.
