Scotts 5th - uh 6th build! now with a video - sorta!
Miles said:
The new Extron sprockets might be a good choice: http://www.accelerationkarting.com/219.html
And thats exactly what I am using. Nowhere near as stiff as the ali - I am seeing some flex under load. Not unsurprising as the kart sprocket carriers are incredibly beefy! Flex is not enough to cause concern so all but 2 of my sprockets are now something other than ali:)
Well here is a vid.
My wife was doing dinner so we couldn't go far - kids about so couldn't go real fast either:(
38mph pass - enjoy - turn down the volume!
btw its quicktime - can't do anything else. oh - and its all about the sound - you know what it looks like!
http://homepage.ntlworld.com/scottclarke/marin/P7280004.MOV
Scott
I have just been running on 36V again - and pop went the controller - well, more like a BANG!
This occurred because the chain tensioner is not pulling tight enough to keep the chain properly seated on the 10 tooth sprocket - leading to current spikes probably in excess 200A.
TBH today the start performance has been getting worse and worse - its all fine once you have been to top speed once - then it seems to 'remember' what to expect - up to that point though its pants.
I have a spare controller so it will be back on the road today.
Next steps are a delrin wheel (or maybe just a a bearing...) above the sprocket to hold the chain on when the rpm's rise and a different esc.
Been looking around at the types used on giant scale and Maxi joker heli's and it seems the Power Jazz is the one to have. I need to check but I think Matt has mentioned this controller as being a good one?
Anyway - specs look awesome and its waterproof so cooling will be a non issue:)
Gonna place an order if I can find positive reviews from people pulling 100A+ continuously.
Scott
So what guage wire is heating up on you? This is getting very interesting. I can't wait to start my own build here in the next couple weeks! Now the dang batts need to come down in price!
Thanks!
Hi tropmonky,
I am using 8 gauge now and I see no heating at all. 12 and 14 gauge heated quite significantly when off-road. On-road the 12 was just warm after several hard launches/hill climbs. I am not 100% sure of the cause of the fire but it is possible the 110C insulation on one of the wires melted...................The connectors (5mm) also proved to be a weak point so now every connection is soldered.
I fitted the other esc yesterday and went for the longest ride yet - did 20.5 miles at 20-25mph with many stops/slow downs since its a walkers/bike path out in the wilderness. Obviously - with only a 24v 15AH pack I was helping things along with the pedals quite a lot of the way - but I never really broke a sweat until the last 2 miles when the cells gave up. I use this path for testing after some road miles - its quite rough, not paved, mix of gravel and mud - it is in fact an old railway line and they pretty much used what was lying around to create the path. It runs for 35 miles and I have only ever made it to the end and back once - on a different bike (pre-use of forums!)
Excellent really considering the cells are the original ones off the black bike - must be 3 or 4 years old now :D
Oh I've gone ahead and ordered that mucho expensive power jazz controller - hopefully that will cure the current induced shut downs on low speed accel.
Scott
Scott
Yes the Power Jazz is awesome! But, it is expensive. Also, Castle Creations makes some crazy controllers these days as well. They even make a 90 volt, 200 amp controller. But, $750! :shock:
Anyway, my Power Jazz will be here in a day or so. I will let you know how it does in my bike when I get it.
Matt
Matt - do post as soon as you have findings! Mine is coming from the USA so will be 2 weeks in arriving:(
I'm surprised there have been no comments about the noise - I expected at least one reply to the effect of OMG!!!?????
Thanks for the info Scott! Whew, that Jazz ESC is a lot more expensive than some of the other ESC's... but if it holds up to a lot of abuse I guess it's worth it... Good to note if I'm going to want to use the larger motor as well! You're bike is sweet! I hope to have something as nice once I'm done... Picking a bike that will work is critical as I'm finding out.
Kyle
Kyle - yes frame choice is all important here!
Care to comment on the noise? I want to hear someone say damn thats noisy - or something - anything! It's almost like the post is invisible - I expected all manner of abuse but nothing - whats up!?!?!???
You win the ES award for having the shortest video clip! :lol:
And yes, the motor is noisy. Sounds like sound effect of a TIE Fighter in Star Wars.
And your little sister is a hottie, if you don't mind me saying so :wink:
j
Sister?!?!? I didn't know I had one!!!!
I presume you mean the one getting in the way of the shot? Thats just a neighbours kid! Now, the one behind the camera - now your talking;)
As mentioned before the motor choice was pretty much the largest for this location. I'm wondering what the bigger motor would do with 24v at around 100a... For the bigger motor a different place will be needed for the location.
Ah, gotta start getting measurements going!
Kyle
lol, dee jay i hope your no older than 16!!!!
Scott have been meaning to ask you, miles too, if you guys are carrying your packs in a backpack (as i intended to do originally) how do you connect? also how do you disconect in the event of a crash? also dont you worry about damaging you bac if you fall on your packs?
Cheers,
D
Scott have been meaning to ask you, miles too, if you guys are carrying your packs in a backpack (as i intended to do originally) how do you connect? also how do you disconect in the event of a crash? also dont you worry about damaging you bac if you fall on your packs?Cheers, D
I use andersons at the moment. these disconnect really easily and I keep them short - if I stand on the pedals without thinking it disconnects - its that short.
Yes I worry a lot - the reason I won't be doing this when it is finished. I am going with a saddle style pack, 9 of the 3700 packs aside - going to use the existing bottle mount for it - plus an additonal 2 quick release fitting at the sides. Not sure what the outer skin is going to be right now - it may end up being silver painted ali to match the bike.
Status update - 128 miles and counting. Mix of smooth and roughish terrain. Cruises nicely at 33mph on 24V (all I am running now) - can go 38 but its quiter at 33. Very impressive acceleration - the 10-30mph accel feels faster than the old black bikes 0-10 running 1KW peak but with a much lower top speed. Pulling away from lights I can easily keep with traffic and in fact prove faster than most cars - those on a leisurely drive anyway! It does feel safer going with the flow - no doubt.
Really needing to get a cam for some onboard footage....
I'm using these connectors. The wire runs up the inside of my seatpost and exits via a hole I drilled near the top. The wire from the backpack is an old-fashioned coiled electric kettle lead which allows a bit of freedom. I've never disconnected accidentally but the connector certainly separates in a crash, as I verified last week.... :mrgreen:
Hehe, that wire is surely rated for 13A? does it not get hot?!?!????
Unfortunately my 3 runs of 8 gauge - whilst I could put them in the seatstay - the exit hole would seriously hinder the structural integrity of the frame!:( I can't reinforce with a bit more seatube either since the wires don't fit down it:(
I'll use a bit of 'capping' attached to the downtubes rear - paint it to match the frame.
Having said that - nothing is set in stone - until the controller arrives I'm just throwing ideas around really.........
Scott
Not that I've noticed - it's air cooled :mrgreen: . Most of the time, I'm not drawing more than 13A, anyway. I realise it's not ideal. I've found a company that coils leads to spec. - I'll get them to create a tight coil of 4 core 15amp rating and then double up the wires. The coiled part can be any proportion of the total length.
The wire down the seat tube is already doubled-up.
Hi Fellas,
Very interesting, i originally had my point 1 pack in a rucksack and used andersons to connect at the back of my seat.
Unfortunately i had the problem you have Scott whereby i would disconnect unintentionally by standing on the bike - i'll have a look at what miles is using (sorry miles just seen the thread link) and maybe that is viable?
after a few rides like this i lashed the batt in the frame and the freedom was unbelievable, however i cant help but think that backpacks are way more stealth - just needs a good rip cord solution so looking at you guys now to see if its an option again?
Cheers
D
not interested at the mo miles if that was for me - Joz is making my custom 123 pack for the traingle so no backpacks for me this time around, wouldn't count it out for future use though :)
Cheers
D
I'm definately going to go with frame mount and the connectors need to be able to handle 200A peaks and 100A continuously - so its big andersons for me!
I've just jetwashed the bike - something I wouldn't even consider doing to either of the other 2 - very very cool:) Pics taken after show close ups of things - I'll reduce them and post them up later:)
nice, pop them up Scott so we can have a ganda, looking forward to pics and more vids later on :)
Cheers
D
