hi...
i have trek 7300, i'm 6'3 and the frame is 21.5". my current fork is 80 mm which came with ah... the frame
. inorder to make the riding more upright, i've resorted to using a stem extender and on top of it place an adjustable stem.
i was told it's not exaclty safe, and would be totally unsafe if i were to do mtb riding.
so i figured i may replace it with a larger fork (a 29er), but finding such a suspension fork for v-brakes (as well as tall one) proved impossible so my LBS suggested i would get a stronger hub for a 15mm qr and he would build a disc brake for it, well as stronger spokes. (i get to keep the rim, yay). then i could get a 120mm fork. this would change the angel of the bike, but since that won't matter cause of the re-inforced structure.
now problem is that would only get me around 4cm, which i don't think is enough, should i get a taller fork? is that even possible? is this entire suggestion safe? i have a 1000 watt ecospeed engine, with evfalcon 48 v 14 ah diamon battery in the frame.
