Here is my homemade battery box. There is a left and right side. One overlaps the other along the center to help keep water out but it will only keep light rain and mud puddle spray out.
To make this, I wrapped the frame with the batteries in plastic and clear tape. I then used about a gallon of bondo to smooth out the wrinkles and add shape to some areas. This bondo layer made the mold that was destroyed after the fiberglassing was completed. I then sanded the bondo fairly smooth and coated it with epoxy to make a hard surface. Then I applied a layer of Vaseline as my release agent and layed down 2 layers of fiberglass. After struggling to pull the hardened fiberglass shell off I then did the other side and struggled again to get the second side off. I then trimmed and sanded down all the edges and filled the low spots with bondo and sanded it smooth. The carbon fiber skin was then added by spraying both the carbon fiber and the fiberglass shell with super77 contact glue and stretching the carbon fiber over the shell. This allowed me lift and reapply the carbon fiber as needed to get the best look with one large piece of fabric for each side. Then I applied 3 coats of epoxy making sure the first coat wet out the carbon layer all the way through. Then I wet sanded it to smooth out the epoxy layer while being very careful not the sand into the carbon fiber layer. Applied the dragon decals then primer and paint. Removed the decals and applied 4 coats of automotive clear.
Good job. Be carefull most epoxy is not UV protected. But if you clear coated the whole thing then its probably ok. I just used clear Gel on my last CF build.
