rosich said:
the above danny posted link was for speedict ebike (previous mode) that information not available on their new website, if you are using new speedict mercury, mars or venus, all information are available on website !
OK. I have a mercury and I got the manual from http://speedict.com/user-guide/mercury/speedict-mercury-client-rev-1-0-0-bw.pdf and it was much easier to get.
It is similar to the other manual but doesn't have the "Simply Cut" menu option so this matches my software.
It shows the "Throttle Range Setup" pg 64-65 under PAS mode only.
Under "Throttle Mode" the first 2 app information screens are not in the manual pg 66. Following the third information screen "Throttle Range Setup" is the next app screen but you have to go back to the PAS mode section of the manual to find it. This is a bit confusing.
I hope the manual review is useful. I didn't find any more clues to solve my problem.
rosich said:
and for the port status report it was designed for support purpose, so it might meaningless for us
Once I looked at the log file I felt I learn't more about the app than through the user interface. I haven't got it working, so I haven't understood it sufficiently yet.
I can see that the user interface provides a mechanism to enter key/value pairs into the app database. These key/value pairs control what the app does. There are many screens, it takes a lot of back and forth to figure it out and some of the terminology is open to different interpretations.
The log file provides a listing of the key/value pairs which I find easier to understand. The name of each key is fairly intuitive but I'd love to see an explanation. I'd also prefer to edit the key/value pairs directly with an editor rather than through the interface.
As an example.
With the key/value pairs:-
ThrottleRangeLow = 250
ThrottleRangeHigh = 250
the Port 4 output value never changes regardless of twist grip position.
After fiddling I see the key/value pairs are now:-
ThrottleRangeLow = 105
and the Port 4 output value changes as the twist grip position is changed but the Port 4 output value never goes higher than 100 and the motor still doesn't turn. I think that is because the Port 4 output is too low, even on full throttle. Therefore, I want to to edit ThrottleRangeLow and ThrottleRangeHigh which I think are setting the range for Port 4 output but I can't figure how to get the values I want through the interface provided. Therefore, I'd rather edit them directly.
