I tried this way on mine MOT half year ago and I couldn't weld 0.1 mm copper. But I experimentally checked, that definitely you need to set shorter pulse time when putting one electrode on the can. With the standard pulse I use for nickel, in case of one electrode on the can I made a hole the "test can".kdog said:That technique can work well- but it is less consistent bc the electrodes are on different surfaces... and once you've popped the nickel on, you can't access the cell. And you have to do twice as many welds and it heats the can more. That's what slotting is for.
K
mkp007 said:'
Exciting update. The following post by ridethelightning and kdog has confirmed the use of a tungsten probe to aid in spot welding copper.
https://endless-sphere.com/forums/v...5&hilit=ultimate+repository&start=75#p1104439ridethelightning said:....the key to making it a smooth job i think is a tungsten tipped electrode. this will not melt like a copper one or stick to the tab. it will also create the resistence needed to create the heat for the weld, at the tip, similar to the effect kdog saw when only using light presseure with his copper electrodes....though...kdog knows all of this, hell, i banged on about it multiple times in a fever of excitement from seeing the copper tab actually welded properly with his MOT welder...
From what I have read on welding copper is copper fumes are very toxic. So you need to do this with a fume hood
For TIG welding copper, the following settings are recommended: DC straight polarity, 2% thoriated tungsten and helium/argon shielding gas.
Here is a link to tungsten electrodes that are 3/32" diameter. They are easy to to cut using a metal cutting grinding blade and easy to sharpen to a point with a belt sander. Just keep the grind marks parallel to the electrode. The tip shape is very important. Based on the images below, I think a 90° angle with a 0.02" diameter blunt end would be best.
https://www.amazon.com/Welding-Tungsten-Electrodes-Thoriated-10-Pack/dp/B013KZNLGG
cut cat said:You will find grinding Thoriated Tungsten is very toxic. If purchasing Tig tungsten eletordes to make your own, Green is pure Tungsten where other colours have other elements. It might be a good idea to find out what tungsten electrode colour / type Sunstone use for copper.
litespeed said:My capacitor discharge welder is 800 watt seconds using 3- 1 farrad and is voltage adjustable to 23.2 volts.
https://endless-sphere.com/forums/viewtopic.php?f=1&t=68521
I'm hoping it has the balls to get this copper spot welding done.
The capacitors I'm using I tested and they are 25 volt & true 1 farrad each.....about 3.1 something total. There used to be a guy on eBay that sold these and has since sold out. They were about $200 for all three about 2nyears ago.
Tom
litespeed said:Finally got around to ordering the tungsten electrodes that Sunstone recommended for copper, http://sunstonewelders.com/product/resistance-tungsten/?attribute_tungsten=EL125TUNG
I'll let you know how it works out. Tom
"...The CD1000DP was set at 310ws energy to weld the .005" copper tab to itself, and at 510ws energy to weld .005" copper tab to .010" copper tab...tungsten electrodes"
