spinningmagnets
100 TW
For a variety of reasons, I now believe that anyone who wants to connect copper ribbon to 18650 cell tips as an electrical bus (regardless of your reasons), should seriously consider resistance soldering.
The thicker the copper bus, the harder it is to spot-weld, but...copper thickness has no effect on resistance soldering. Electricity is passed through he two parts (the 18650 can, and the copper ribbon), and the solder gets hot, with that heat radiating outwards until the desired result happens (two seconds?). In fact, with resistance soldering, a thick copper bus would heat-sink the heat away from the joint as soon as the power to the RS unit is cut.
If this interests you, I started a thread a wile back to compile info on resistance soldering / RS.
https://endless-sphere.com/forums/viewtopic.php?f=14&t=88965
http://technitoys.com/diy-resistance-soldering-outfit/
