so a while ago now, my efforts at finding a nickel alt in copper alloys proved friutless (mostly bc of the volumes i wanted, not bc they dont exist), so i have come up with a DIY version of some high power commecial designs.
i'm building a 20s10p 30q pack that needs to be able to discharge at 120a (peak), even if i used broad sheet .2mm Ni id be required to do a lot of beefing up with solder and copper. As batteries get more and more powerful, ni is going to become increasingly inadequte, and its freaking expensive, but it remains the best welding material so far.
so im working on a different hybrid Ni:Cu spotweld only soultion. this technique isnt new, but im not sure if its been done it has a few benefits, and a few draw backs,
pros:
dual current exit for the Ni means effectively twice the nickel amount per cell
Very short path for the nickel- less loss
all copper-nickel welding is done off the cell with opposing electrodes , also this allows for using thicker copper (i welded 0.2mmNi to 0.15mmCu with ease)
can accomodate any arrangement of cells
uses far less nickel than a broad sheet alternative reducing cost substantially
cons
time consuming
requires setting up with a hole punch and opposed electrodes
The process is to cut out a piece of copper to do the parallel and series connects between adjacent groups.
Punch holes directly over the cell ends
Weld nickel over holes
Weld nickel through holes to battery
I can imaging alot of people saying why bother... and for low power packs this would be overkill, but i think its a good solution if broad nickel isnt going to cut it.
here are some pics to explain
im pretty sure ill use this technique for my current build
i can punch out a copper sheet in about 5 mins (which is copying the template), for the unique shapes it takes about 15mins. this incudes shaping and punching.
the welding of copper to the nickel is super easy and takes about 1min for a strip.
all up itll take quite a few hrs, and im still testing as i go so probly even more time there.
not sure if ill use .1mm cu or .15mm. ill order both to see if i can get consistent welds with the .15mmCu
its definitly stronger than the .1mm so i think ill try and use it.
ill update with some more pics when i get the chance
k
